OBX LSD install
Old Mar 30, 2005 | 02:17 PM
fullracegsr's Avatar
Default OBX LSD install
i bought a 99-00 si obx lsd and in the process of installing it. Went to go check the clearance for the shim and the diff was binding with no clearnace at all. After putting the two diffs side by side i noticed that the obx unit has a ledge on the speed gear side that causes the bearing to sit higher on the obx unit. The ledge is causing the diff to be too tall to put the case on even with the bearing out. I tried all kind of oem bearings and even called bearing shops. Right now im just stuck cause i cant find anything that will work and i emailed obx but no response yet. Anyone have this problem or any suggestions?? no you get what you paid for responses thanks
Old Mar 30, 2005 | 03:51 PM
Default Re: OBX LSD install (fullracegsr)
i just found out that si bearings and gsr bearings may be different...
si-80*40*18
gsr-80*40*17
can anyone confirm??
Old Jan 5, 2006 | 09:31 PM
eg:R's Avatar
i want to know, installing mine soon
Old Jan 6, 2006 | 12:04 AM
D@nnY's Avatar
Default Re: OBX LSD install (eg:R)
they are different ...most gsrs use tapered roller bearings however newer gsrs switched over to the ball bearings liek the type R has...
the b16 si and the integra LS use a bearing like the type r but they are smaller
Old Feb 9, 2006 | 12:57 AM
tegaholic's Avatar
any updates?
Old Feb 12, 2006 | 07:44 PM
vtac sonn's Avatar
Default Re: OBX LSD install (tegaholic)
been interested in getting this lsd for my turbo gsr setup just looking to get some feedback on quality and how well it performs
PR8urVtec
Transmission & Drivetrain
10
Jan 29, 2016 08:19 AM
speeddave
Apr 29, 2009 11:35 PM
DaiJekBok
May 23, 2006 01:45 PM
m3bluegsr
May 21, 2004 02:08 PM
