OBD2A Primary O2 sensor wiring/plug question!
Old Dec 21, 2004 | 09:35 PM
HybridKOOP's Avatar
Default OBD2A Primary O2 sensor wiring/plug question!
Subject: '98 Civic DX
Transplant: '98 JDM GSR swap
Problem: I am running a chipped P28 in the car with a OBD2A to OBD1 conversion harness. Obviously, a P28 only looks for a primary O2 sensor. I used the cars original OBD2A D16Y7 engine harness on the GS-R motor. There were two plugs for the primary and secondary O2 sensors on the D16. I only need to extend ONE of these down to the rear of the GSR header to accomodate the primary O2 sensor that the P28 will be reading from. I need to know WHICH plug on the engine harness to extend (I know it's near the transmissions reverse light plug), but I am unsure as to what WIRE COLORS they are exactly. I will then also need to know what wire color corresponds to what wire color on the O2 sensor itself (green, white, 2 blacks).
Thanks.
Old Dec 21, 2004 | 09:51 PM
Mike K's Avatar
Default Re: OBD2A Primary O2 sensor wiring/plug question! (HybridKOOP)
whats up bitch ***. send me an IM, and i'll give you my cell number. i work at honda now, and i have access to all the service manuals n' ****. call me tomorrow.
da59block
Nov 16, 2011 11:25 AM
Dukie432
27
May 6, 2009 10:08 AM
zach1288
Mar 6, 2009 04:02 AM
hondaboy90
Oct 1, 2006 06:03 PM
