OBD2 to OBD1 B20 Block conversion
Old Jan 6, 2010 | 04:44 AM
fv8s's Avatar
Default OBD2 to OBD1 B20 Block conversion
so i found a steal on a fully built b20b block and instead of building my b18 i have decided to go the b20 vtec route. it is tapped for lsv already has eagle rods and .20 over bore with forged pistons. it is also block guarded. my questions are...... will my LS tranny bolt up without any modification? im assuming it will but need an answer..... what do i need to do to convert the b20 to OBD1 without any CEL lights! i have heard i need sensors, water pipe and all that fun stuff. help is appreciated. thank you
Old Jan 6, 2010 | 07:26 AM
fv8s's Avatar
Default Re: OBD2 to OBD1 B20 Block conversion
bump for help
Old Jan 6, 2010 | 12:35 PM
boostedEF91's Avatar
tranny will bolt on fine. nothing different. all b series are the same bolt pattern.. just put the motor in and hook up the necessary sensors. don't need nothing to convert. unless your car is obd0 or obd2 then you will need a jumper harness for the ecu. but other than that you're fine . unless you need to run v tec wires but thats no biggie.
Old Jan 6, 2010 | 01:05 PM
fv8s's Avatar
thanks for the help boosted... but what do you mean by running VTEC wires im sort of new to the whole Honda scene and its my first b20 VTEC build
Old Jan 6, 2010 | 04:13 PM
If your car didn't have a vtec motor you will have to run vtec wires and pin them into the ecu. or sometimes when you by a jumper harness they will be haded with the harness so that you can run to the vtec solenoid.
Old Jul 8, 2010 | 01:24 PM
EdSales's Avatar
Not to jack a thread and sorry for bringing up an old one, but I am looking into doing a B20B Swap into one of my EGs. The EG is OBD1, and I believe that the B20B is OBD2. What your saying is that I can just put the OBD2 B20B into my OBD1 EG there is nothing I need to convert? It'll just plug up with my harness and P30 Chipped Hondata S300?
Old Jul 12, 2010 | 11:24 AM
fv8s's Avatar
if your sensors/ alternator are OBD1 it will be a plug and play with your ODB1 harness. i also ran my VTEC with some advice
Happyfeat2006
12
Mar 11, 2009 12:47 PM
haroldthefly91crx
Apr 21, 2008 04:50 PM
tranzvision
Dec 12, 2005 05:51 PM
Train
May 9, 2003 07:56 PM
