obd2 injector problem...need help...
Old Aug 15, 2010 | 03:29 PM
BB6matik's Avatar
Default obd2 injector problem...need help...
i have a 95 b16 head/ 94 gsr block using obd1 p72....car came with obd2 injector clips and obd2 injectors....wanna know how to put the obd1 injectors on....will i need to change the clips? if so, are the wirings going to be the same if i just cut and replace it with the obd1 clips???
Old Aug 15, 2010 | 03:49 PM
fcm's Avatar
fcm
Old Fart
Default Re: obd2 injector problem...need help...
If you have to change the clips, [I do not know] then even if wire colors/tracers are different, wiring the new clips to the engine harness, [injector leads] is simple...
The lead that is the same color on all four injector plugs, [both OBD1 and OBD2] is the 12V+ from the PGM-FI Main Relay, so as long as you connect the wires that are the same color on each set of plugs, the other lead, no mater what colors they are are injector control from ECU/ECM, [12V- pulse].
You may or may not need an injector resistor "pack". 94
BB6matik
Aug 15, 2010 05:54 PM
jewpont
Jul 11, 2009 01:24 PM
Black R
Nov 10, 2007 04:31 PM
EKB18BPR3
May 6, 2005 08:07 AM
