OBD1 P30 ECU Question
ok...i am trying to wire a knock sensor to my p30 ecu and im not sure what pin on the ECU is the knock sensor...i know it is Pin D3 but i dont know what pin is the lead pin.
This is the Image that i have to work with
Are you confused of the PIN location?
If so, the pin location of D3 would be the right side plug, top row, 2nd pin over counting from the right.
This is looking at the plugs with them plugged into the ECU with the plug clips on top.
Dont view it with the harness unplugged from the ECU otherwise the pin locations will be interpreted incorrectly.
ODD numbers on top row,
EVEN numbers on bottom row.
So D6, which is your VTEC oil pressure signal would be over 1, and down 1 from your D3. Get it?
Good luck!
Good luck!
