obd1 gsr engine to obd2 ls integra questions
Old Jan 28, 2006 | 03:13 PM
turbodan4's Avatar
Default obd1 gsr engine to obd2 ls integra questions
i just bought a 95 gsr engine for my 96 ls my car has obd2 and the engine is normally and obd 1 i was wondering what i would need as far as dizzy, wiring harness, what year ecu(im planning on getting and aem system but i was wondering which one i need), I was just wondering this to be sure about the swap.
Don't say search please cuz i tried that and only came up with different info.
thanks
Old Jan 28, 2006 | 05:21 PM
86si's Avatar
Default Re: obd1 gsr engine to obd2 ls integra questions (turbodan4)
your gonna have to run a obd1 ecu with a jumper cause the obd 1 block has no crank sensor unless you want to get an obd2 oil pump so you can bolt on the crank sensor. i would try to keep it obd2 so you can pass inspectino with no CEL
wowy978
Engine Management and Tuning
Oct 7, 2008 11:05 AM
turbodan4
Jan 29, 2006 11:53 PM
DOHCon15s
May 14, 2004 08:59 PM
3rdGteg
Dec 2, 2002 05:38 PM
