OBD1 ECU, which?
Old Mar 24, 2003 | 07:43 PM
r7's Avatar
r7
Default OBD1 ECU, which?
I was/am looking for a P30 ecu, but found them to be scarce. Someone told me that I could just use a P28? and chip it or something?
1990 B16A in 88 CRX, OBD0 right now, switching to OBD1
+ doing turbo install and obd1 conversion @ same time, going with hondata s200
Old Mar 25, 2003 | 09:49 AM
r7's Avatar
r7
Default Re: OBD1 ECU, which? (r7)
anyone?
Old Mar 25, 2003 | 12:24 PM
joe_bocc's Avatar
Since your going with Hondata can't you use either one? And if thats true, just go with the esiest ECU to find.
Old Mar 25, 2003 | 07:03 PM
TimoneX's Avatar
New User
The P28 and Hondata will be fine. The only relevant difference is the absence of a knock sensor. The P30 looks for one and the P28 does not. Stock knock sensors are useless however so it won't matter one way or the other.
Old Mar 26, 2003 | 12:50 PM
r7's Avatar
r7
Default Re: OBD1 ECU, which? (TimoneX)
ok, i'll find a obd1 ecu. =o
also, can i use peak and hold injectors with obd1?
Old Mar 27, 2003 | 11:41 AM
TimoneX's Avatar
New User
You'll require resistor boxes to use the lower resistance peak and hold injectors.
MonkeyParty
May 6, 2014 02:04 PM
89silverb16crx
15
Apr 14, 2004 10:02 PM
leadfoot78
Dec 15, 2003 01:28 AM
91hatch_on17's
Oct 27, 2003 02:35 PM
NOSED_CRX_VTEC
Oct 25, 2003 11:00 PM
