obd1 distributor any better than an obd0?
Old May 29, 2003 | 04:30 AM
Bontke's Avatar
Default obd1 distributor any better than an obd0?
I have been looking into converting to obd1 and have seen people rewire obd0 distributors to work with obd1 computers. Is there any performance gain in using obd1 over obd0 distributors? Or are they just the same distributor with different wiring plugs? I have searched to no avail.
Old May 29, 2003 | 04:35 AM
HATCHFREEK's Avatar
same dist, just different plugs...
Old May 29, 2003 | 05:46 AM
Bontke's Avatar
Default Re:
Does that go for the injectors also?
Old Jun 1, 2003 | 09:12 AM
Bontke's Avatar
Default Re: Re: (Bontke)
anyone?
Old Jun 1, 2003 | 09:35 AM
Kataku2K3's Avatar
Default Re: uhhh, no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHFREEK &raquo;</TD></TR><TR><TD CLASS="quote">same dist, just different plugs...</TD></TR></TABLE>
Nope, they're actually not the same, their internal spline fires at a different pulse rate making a nonOBD distributor different that an OBD1/2... This is why an nonOBD distributor is incompatble with an OBD1/2 ECU, or an OBD1/2 distributor with a nonOBD ECU... OBD1/2 are the same with a different connectors, and there's absolutely no performance advantage. If the car is running "factory" ECU then I prefer an OBD1 system with all OBD2 sensors/connectors... The newer plugs just look cleaner and as some of you probably know, I am very very picky about wiring... The injectors are also different... Just about all '91 and older injectors are low impedance and run an inline restistor pack... '92+ OE Honda injectors are all high impedance (their resistor is built into them)... It is however possible to run nonOBD injectors with a OBD1/2 ECU or vise versa... That's just in the wiring... Hope this answers your question... Peace
Old Jun 1, 2003 | 09:51 AM
Bontke's Avatar
Default Re: uhhh, no (Kataku2K3)
That is exactly the answer I am looking for. So basically you could ditch the injector resistor box with an obd0 setup and use newer obd1/2 injectors?
AzCRX
Apr 15, 2007 04:23 PM
fin781
Feb 10, 2007 11:32 AM
91dxcrx
Jan 22, 2006 05:46 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
