OBD1 auto ECU to manual conversion. PICS
Old Oct 24, 2004 | 11:48 AM
  #26
Joseph Davis's Avatar
Default Re: OBD1 auto ECU to manual conversion. PICS (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">am i good to go? </TD></TR></TABLE>
Old Oct 24, 2004 | 01:32 PM
  #27
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: OBD1 auto ECU to manual conversion. PICS (J. Davis)
sweet! thanks.
Old Oct 27, 2004 | 12:56 PM
  #28
GiT LaO'd's Avatar
Can this be done to a OBD I JDM P72 as well??? Most of the things I have seen after searching is for P28's...
Old Oct 27, 2004 | 02:08 PM
  #29
Default Re: (jaybee)
Wow, all the simple basic questions are becoming quite taxing.
http://wiki.pgmfi.org has the answer to ALL your ECU questions. ALL. Go use it.
Old Nov 3, 2004 | 05:00 PM
  #30
TekSI's Avatar
Default Re: (J. Davis)
similar question here. after removing the 2 resistors and replacing one w/ a jumper, is there anything else to do? there are two transistors(i believe) in the auto that the manual does not have. do i remove these or are they nonfunctional after changing the resistor setup?
Old Nov 13, 2004 | 05:14 PM
  #31
D3U1LT's Avatar
Default Re: OBD1 auto ECU to manual conversion. PICS (EGhatched)
can you post the pictures up again? looking to do the same thing but dont know where to put the jumper wire when jumping RP17, and 18.
Old Nov 15, 2004 | 06:47 AM
  #32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Wow, all the simple basic questions are becoming quite taxing.
http://wiki.pgmfi.org has the answer to ALL your ECU questions. ALL. Go use it.</TD></TR></TABLE>
Old Jun 26, 2006 | 05:06 PM
  #33
kikidawn's Avatar
How come i can't see any of the picture?
Old Aug 8, 2006 | 06:04 PM
  #34
suspendedHatch's Avatar
Default Re: OBD1 auto ECU to manual conversion. PICS (kikidawn)
Since I had to dig quite a bit to find this info, here's the link: http://www.pgmfi.org/twiki/bin...anual
Old Sep 7, 2009 | 05:42 PM
  #35
RyanA's Avatar
https://honda-tech.com/forums/showthread.php?t=858920
Do it yourself or I'll convert for $10
Old Aug 29, 2011 | 12:50 PM
  #36
Ruben19's Avatar
Sorry for bringing an old thread back. My question is: which one controls the speedometer? I have the RP17 disconnected and the RP18 jumped. My odometer is going crazy because this guy messed with it before.
z3r0
Feb 15, 2014 01:37 PM
stiffinEK
Apr 28, 2011 10:49 PM
inline4
13
Oct 15, 2010 12:22 PM
ALL-OUT
Aug 30, 2010 03:27 PM
XES
Aug 3, 2004 02:19 AM
