OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!!
Old May 23, 2006 | 04:32 AM
Mr.Chow's Avatar
Default OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!!
Last night me and a buddy spent all night doing an 0bd1 conversion on my 90' crx si, with a jdm b16a. We swapped and wired in an obd1 dizzy and the obd1 jumper harness, wired in a four wire O2 sensor, vtec pressure switch, etc. , all wires seem to be connected correctly. On a test drive the car idles at about 1.5k and seems to drive fine. However with one major problem. It is very sluggish to rev and fuel seems to cut off at around 3.5-3.7k rpm. Its also throwing a cel code, but im not sure what it is. We never disconnected the battery during the whole process and we checked the timing and that seems to be fine. The guy that used to have the car before me had an itb setup, using standalone fuel management, but i dont think that would affect anything now.
My opinion its in limp mode right now, but could someone who may have had this problem before please offer some addvice.
thanks!!!
Old May 23, 2006 | 04:40 AM
B18C_EJ8's Avatar
Definitely in limp mode. Stupid question maybe, but you changed the ECU, right? Didn't say in your post...
If you did, then I would start by retrieving the CEL error code and going from there... Search for that procedure.
Old May 23, 2006 | 09:14 AM
prwil3030's Avatar
Default Re: OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!! (Mr.Chow)
We recently swap a b16a2 into my brother 91 CRX Si, with the same convertion harness that you have, with a chipped p28 ecu. After trying an obd1 b16 distributor we were getting the same problem and the code 8 (TDC), wich means that were having no spark causing the same problem as you at about 4500 rpm. We decide to wired a b16a2 distributor to save some money, but we didnt find the right pin out, and wired it wrong. The solution, we bought a distributor from a 95 Del Sol Si with the b16a2 engine and order a distributor convertion harness ($25.00, less headache) and the problem is fix now. The motor runs great, no cels and no problems at all. One more thing, double check the o2 sensor make sure is right. Hope this help a little, good luck.
Old May 23, 2006 | 12:11 PM
Mr.Chow's Avatar
Default Re: OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!! (prwil3030)
okay so basically you just ordered a dizzy harness to a obd2 dizzy and everything worked fine? so could the car still run with a bad wire in the duzzy?
and yes I changed the ecu with a p08, which is the jdm equalivient to the p28 in the states i believe. It's socketed and running a spoon program currently. Im getting a fuel cut-off around 3700 rpm, sounds similar to the above problem, but im not sure if you're suggesting buying a new dizzy or just the harness??
Old May 23, 2006 | 12:16 PM
Mr.Chow's Avatar
could it possibly have something to do with using the obd0 injectors?? I heard it makes no difference
Old May 23, 2006 | 01:46 PM
prwil3030's Avatar
No, the b16a2 or obd2 dizzy dindnt work for me because I wired it wrong there is an easy way to do it but you need to get this, I bought a dizzy out of a 95 del sol, the one that came with the b16 engine wich is obd1. Then I ordered that distributor conv. harness obd0 to obd1, this will save you a lots of headache, look I just find this info for you, read it, hope you understand it, becuase this might be your chance to fix your problems:
http://diy.prostreetonline.com...id=40
For the record, we still using the obdo injectors + oem fuel pump, working fine.
Modified by prwil3030 at 1:03 PM 5/24/2006
Old May 23, 2006 | 02:00 PM
prwil3030's Avatar
One more thing, P08 is out of the JDM d15, P30 is the one for your JDM b16a, I will change that ecu to a P28 or P30. You need to make a little bit more research.
Old May 24, 2006 | 04:46 AM
Mr.Chow's Avatar
I heard that the p08 was the equivelent to the p28. The p08 is just the jdm version. ****.
Old May 24, 2006 | 10:15 AM
Mr.Chow's Avatar
bump it up. I need more advice.
Old May 24, 2006 | 11:57 AM
alphaek's Avatar
Old May 24, 2006 | 12:07 PM
prwil3030's Avatar
Default Re: OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!! (alphaek)
I think your problem is in the distributor harness wiring.
Old May 25, 2006 | 04:38 AM
Mr.Chow's Avatar
does anyone else have an opinion on the dizzy harness wiring???
I would think if you even had one wire wrong the car wouldnt even start, or it would idle crazy or something like that.
It was just such a bitch getting all the wires connected properly back into the plugs that i dont even want to think about going back and disconnecting everything if i dont have to.
Should have got that damn conversion harness in the first place and i wouldnt have this problem.
Old May 25, 2006 | 09:48 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Chow &raquo;</TD></TR><TR><TD CLASS="quote">I heard that the p08 was the equivelent to the p28. The p08 is just the jdm version. ****. </TD></TR></TABLE>
-Many people convert the P08 to run a bseries vtec setup.
-Check to see if the ecu is good. Get any OBD1 ecu just to put in the car and see if it clears your codes.
-Find out what codes you are throwing.
-Who's conversion harness did you buy?
Old May 25, 2006 | 12:04 PM
Mr.Chow's Avatar
Default Re: OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!! (Blown90hatcH)
I got one off of ebay. The guy had a lot of good feedback and the harness looked pretty well made. I'll try putting the p08 in my friends coupe and let you guys know what happens.
Old May 25, 2006 | 02:50 PM
what codes are you throwing?
Old May 27, 2006 | 08:48 AM
Mr.Chow's Avatar
im throwing a code 20, electrical load sensor???? what's that ??
Old May 27, 2006 | 12:35 PM
Mr.Chow's Avatar
ok now using the chipped p08 I switched it back to stock mode so now it thinks its a d15b vtec and revs to the 7200 rev limit. Vtec seems to hit around 5500 and the idle is stable. But now i throw a code 20 and im not really sure what electrical load sensor means or what that effect, how to fix, etc. Any input would be greatly appriciated.
Old May 28, 2006 | 02:12 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Chow &raquo;</TD></TR><TR><TD CLASS="quote">ok now using the chipped p08 I switched it back to stock mode so now it thinks its a d15b vtec and revs to the 7200 rev limit. Vtec seems to hit around 5500 and the idle is stable. But now i throw a code 20 and im not really sure what electrical load sensor means or what that effect, how to fix, etc. Any input would be greatly appriciated. </TD></TR></TABLE>
hmm..so a bad programmed eprom was on there...
I was going to mention that perhaps the jumper harness was faulty.
Try resettting the ecu and see if that clears the code 20 CEL...
and yes, a P08 is like a JDM version of a P28 ecu ... a sohc VTEC ecu.
Old May 28, 2006 | 10:27 AM
Mr.Chow's Avatar
Default Re: OBD0 to OBD1 conversion. rev limit 3700! PLEASE HELP!!! (Katman)
how do you reset an ecu???
Mr.Chow's Avatar
nm that was a dumb question.
Old May 29, 2006 | 09:35 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Chow &raquo;</TD></TR><TR><TD CLASS="quote">nm that was a dumb question. </TD></TR></TABLE>
heh,
you can either unplug the ecu from the wire harness for about a minute or more, or pull the ECU fuse for more than 30 seconds..
Old May 29, 2006 | 03:03 PM
johnnylaw's Avatar
i've had this problem. similar project. we use crome to make maps and make sure you remove checksum routine. that will put the car in limp mode. some ecu's work without doing it but from now on, every map i make i remove checksum first thing. I also had problems with the distributor wiring. the directions i got were completely wrong. i'm tryin to make a diagram for distributor wiring conversions that i know is right
Old Jun 1, 2006 | 11:58 AM
Mr.Chow's Avatar
Default Re: (racingtechnologyco.com)
good info. thx
pm'd
dem0nk1d
Aug 8, 2007 02:17 PM
Mr.Chow
Jun 15, 2006 12:06 PM
lovitalracer
Mar 19, 2005 09:50 PM
650EF9HATCH
Feb 1, 2005 11:21 AM
altoid
11
Jan 21, 2005 08:49 AM
