OBD 0 pinouts
Hey, i was just wonderin how you read OBD 0 pins. I've gotta drop my friends B16A into his CRX. I've done a lot of OBD 2 swaps and i know that the pins go from left to right A1, A2, A3, A4 and so on. I also have done OBD 1 and know that the pins go up, down, up, down. Thanks for the help!!!
i dont think there is anything called OBD 0
but if you are refering to JDM wires for B16A check the link below.
the plugs should have some numbers on them, eg the start and ends of a sequence...
you should also be able to work out the sequences from the colour codes on this chart: http://<a href="http://www.geocities...gines.html</a>
i hope this is will help you.
t..
t..
