O2 wiring hell
Old Feb 24, 2004 | 08:43 AM
t25hatch's Avatar
Default O2 wiring hell
alright... i have a VX wiring harness in my car, and when i bought a d16z6 i couldn't pick up the wiring harness. Well i now have the wiring harness on everything, but the d16z6 motor's O2 sensor is a 4 wire sensor, and the VX harness has 5 wires to pulg up. Im at a point where i don't knwo what wires goes to wat... can anyone please help me?!!!! thanks in advanced
Old Feb 24, 2004 | 12:06 PM
Bigjussin's Avatar
Default Re: O2 wiring hell (t25hatch)
do the colors of four of them match? u might just have a spare ground....
Old Feb 24, 2004 | 12:28 PM
Usdm1's Avatar
just do a search on 4 wire o2. all you need to do is wire the o2 direct to the ECU.
Old Feb 24, 2004 | 02:35 PM
dfoxengr's Avatar
Default Re: O2 wiring hell (Bigjussin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjussin &raquo;</TD></TR><TR><TD CLASS="quote">do the colors of four of them match? u might just have a spare ground....</TD></TR></TABLE>
its not a spare ground. vx is a wideband sensor. you have to search its ehre somewhere and wire ur 4-wire straight to the ecu
Old Feb 24, 2004 | 03:40 PM
t25hatch's Avatar
Default Re: O2 wiring hell (hybridvteceg)
http://tech2.hybridgarage.com/..._obd1 ... ok i checked it out but here's wat i got. Out of my oxygen sensor, i have 4 wires, 2 black, 1 white, and 1 blue. The two black are the heater elements, the white is sensor ground, and the blue is sensor signal. The vlue sensor signal goes to #D 14 White/Red wire. One of the two black heater elements goes to #A6 which is ORAN/BLK wire. Can i ground the white anywhere, and also what about the second black heater element? Please help, thanks in advanced....
Old Feb 24, 2004 | 04:08 PM
dfoxengr's Avatar
no blacks are both grounds, white is signal sending to ecu, and blue is ignition power
Old Feb 24, 2004 | 04:28 PM
Kataku2K3's Avatar
I made this diagram awhlie back (EDIT: wow, just over a year ago) but hopefully it'll help you somewhat... Let me know if anything is unclear... Good Luck
Old Feb 24, 2004 | 06:06 PM
Bigjussin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">no blacks are both grounds, white is signal sending to ecu, and blue is ignition power</TD></TR></TABLE>
yesssss!...10 points for me for being right for once....sorry all it doesnt happen much
peace
Old Feb 24, 2004 | 09:14 PM
t25hatch's Avatar
hey thanks a lot man, it helps an inredible amount. i will try it tomorrow and post results. Thanks again
Old Feb 27, 2004 | 08:57 AM
IntegraXSi's Avatar
Nice I will be useing this
beaterman
Jun 11, 2008 10:21 AM
ham
May 31, 2006 01:49 PM
dturbo
Jun 8, 2005 06:16 PM
JCracer723
Dec 4, 2003 06:15 PM
splitime
Sep 7, 2002 07:27 PM
