O2 signal wire?
I have a 2002 civic and i need to hook up my air/fuel gauge but i dont know which wire is the signal wire. There are 4 different color wires after the connector. There is a green, gray, and two blacks with stripe. Which is the signal wire? HELP ME PLEASE....
Yea you will want to run it off the signal line.. white wire most of the time but i guess in ur case it changes but that's fine.. I like to run them directly off pigtail a few inches up from the plugs, just cuz i like it to look clean.. Sorry i don't have pinouts for the 02 civics but you can trace the wire if your really want to tap it in by the ECU. Just use a voltmeter with a continuity tester.. Have fun
SpeedMonkeyRacing
Oct 20, 2004 01:33 PM
Mini-mEK4
Apr 29, 2004 07:29 AM
