Which o2 sensor does the PLX 300 use?
Old May 5, 2005 | 03:19 PM
amit's Avatar
Default Which o2 sensor does the PLX 300 use?
im wondering if the plx 300 uses the universal bosch sensor or the ntk sensor which will cost an arm and a leg
Old May 5, 2005 | 04:55 PM
Lord Helmet's Avatar
Default Re: Which o2 sensor does the PLX 300 use? (amit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amit &raquo;</TD></TR><TR><TD CLASS="quote">im wondering if the plx 300 uses the universal bosch sensor or the ntk sensor which will cost an arm and a leg</TD></TR></TABLE>
You went on their website yet?
http://www.plxdevices.com/M-Series_FAQ.htm
Old May 5, 2005 | 05:06 PM
amit's Avatar
Default Re: Which o2 sensor does the PLX 300 use? (Lord Helmet)
thanks for trying man . but it didnt really answer my question, they only mention that they use both bosch or ntk with different series controllers. But which one do they use with the m-300
Old May 5, 2005 | 05:16 PM
IN VTEC's Avatar
Old May 15, 2005 | 02:30 AM
Takumi Fujiwara's Avatar
Default Re: Which o2 sensor does the PLX 300 use? (IN VTEC)
I noticed they offer the NB to WB convertor.... so how does that work if it's connected to the 52mm gauge? It's either rich, ok, or lean... will it display correct numbers on the dial?
pinoyk20
Aug 7, 2007 06:39 AM
93supercoupe
Aug 27, 2006 11:52 AM
See Are X
Aug 22, 2004 11:17 AM
bankhead83
Apr 19, 2004 05:40 PM
Jebus
Mar 21, 2003 02:43 PM
