o2 sensor bad?
Old Feb 17, 2005 | 07:15 PM
Antilag's Avatar
Default o2 sensor bad?
What do you guys think? I just installed a turbo in a friends car, it has thrown catylist efficiency codes once in awhile in the past due to high flow cat on a obd2 setup. This guy had to reweld up my exhaust to fit the down pipe, he cut and made a flange and welded right next to the o2 sensor without dissconnecting it. I now have a o2 sensor code throwing instead of a catylist code. When i drive it in midrange when i hit boost it stops at around 4500 rpm and doesn't want to rev higher, now the gas mileage went through the toilet, and it idles like ****, at a stoplight it bogs at around 400-500 then intermittenly jumps up to 1000 and smooths out for a few seconds, then drops back down. does this sound like an o2 to you? it threw the code last night, and wasn't really idleing bad last night, it started to idle shitty today. Just want some input on if this was a problem for you and if the problem dissapeared when you replaced it. thanks.
Old Feb 17, 2005 | 10:28 PM
PrettyLude's Avatar
it sounds like an o2 sensor problem
but if that catalyst inefficiency code comes back get an o2 sim to cure the code
Bossup!
Sep 9, 2009 07:35 PM
skata89
Apr 3, 2008 12:26 PM
vietboiracer0
Dec 30, 2005 08:00 PM
apok
May 16, 2005 09:52 PM
SOHC4life 96
33
Oct 11, 2004 10:19 AM
