o2 heater circuit malfunction
Old Mar 3, 2013 | 12:13 PM
  #26
S2kneub's Avatar
Default Re: o2 heater circuit malfunction
considering it grounds through the ecu, does that mean i need a new ecu?
Old Mar 3, 2013 | 12:19 PM
  #27
fcm's Avatar
fcm
Old Fart
Check for power at IGP1 and IGP2, power is supplied by the injector relay. 94
Old Mar 3, 2013 | 12:23 PM
  #28
S2kneub's Avatar
since it grounds through the ecu, do i need a new ecu? it grounds through the ecu so that it can cut ground and turn the heating element off once it reaches temp. can i just run a dedicated ground and allow the heater to run constantly?
Old Mar 3, 2013 | 12:25 PM
  #29
S2kneub's Avatar
not sure what you mean by igp1 and 2 but i'll check the relay
Old Mar 3, 2013 | 12:44 PM
  #30
S2kneub's Avatar
igp2 is getting 12v and i dont know where igp1 is. can i run a dedicated ground? will it burn out the sensor?
Old Mar 3, 2013 | 02:43 PM
  #31
fcm's Avatar
fcm
Old Fart
Igp1&2 are signals for the ECU/ECM to turn on, they will be the same color leads as the output of the injector relay, [that is the lead on your PGM-FI Main relay that has power when you turn on the ign.] those color leads will be the only two leads at the ECU/ECM that are that color.
Both IGP1 and IGP2 must have power when ign. switch is in the run AND the stat positions.94
Old Mar 3, 2013 | 04:50 PM
  #32
S2kneub's Avatar
if they didn't have power, wouldn't i be having other issues besides just the heater circuits in my o2 sensors?
Old Mar 4, 2013 | 08:15 AM
  #33
S2kneub's Avatar
is it just the one guy who knows anything on this forum?
Old Mar 4, 2013 | 10:40 AM
  #34
fcm's Avatar
fcm
Old Fart
No, you can not run "dedicated" grounds to the sensor, or Honda/Acura would have done that, [I assume].
Find IGP1 and test it, it will bew the only other lead to the ECU/ECM that is that same color.
You may not have other probems if IGP2 has power but IGP1 does not, I have never run into one that has power to one IGP and not the other it's always been no power to both.
It is something I will have to check out, next time I have a Honda/Acura in the shop, both IGP1&2 get their power from a single lead from the injector relay that splits into two leads someplace betweem the PGM-FI Main Relay and the ECU/ECM. 94
Old Mar 4, 2013 | 11:11 AM
  #35
S2kneub's Avatar
alright i found igp1, i think. it reads 12v as well.
Old Mar 4, 2013 | 02:08 PM
  #36
fcm's Avatar
fcm
Old Fart
Then it is looking like the ECU/ECM is bad.
Have you checked continuity of the ground supply lead(s) between the ECU/ECM and thew sensors? 94
Old Mar 4, 2013 | 03:02 PM
  #37
S2kneub's Avatar
no, but i used a different harness with the same result. i got my aem ecu working and i'm gonna see if the o2 sensor heats up with it tomorrow.
Old Mar 5, 2013 | 09:38 AM
  #38
S2kneub's Avatar
sure as hell, the ecu wasn't grounding the sensor. thanks for the help, fcm
Old Mar 5, 2013 | 10:50 AM
  #39
fcm's Avatar
fcm
Old Fart
YW.94
2k1 SSM GSR
Jan 2, 2009 03:04 PM
mckrank313
Aug 4, 2007 02:20 AM
gtlaw1
11
Jul 18, 2007 07:27 AM
beaterdriver
Mar 4, 2005 12:36 PM
Qwikrex
Jul 29, 2002 07:31 PM
