Number One Cylinder position sensor b20v
Old Jun 20, 2009 | 01:28 AM
sitinthehall's Avatar
Default Number One Cylinder position sensor b20v
I've got a b20vtec that is throwing a number 1 cylinder position sensor code. Has a known good distributor, with good timing. I'm running the vtec waterpump with the vtec timing belt. I've tried several different ecus, in two different cars, 2 different wiring harnesses, 3 different distributors (one is brand new), and I can't get code 9 to go away. Car continues to run in limp mode because of the code. No other codes are present. I'm running an obd2 - obd1 conversion, but wiring is not the issue as the code 9 was being thrown in the obd1 car it was running in with the obd1 harness. Any suggestions?
Before you flame, I have searched all over and have found nothing.
Old Jun 20, 2009 | 01:41 AM
RareSpirits's Avatar
Default Re: Number One Cylinder position sensor b20v
Here is some google information.
Civic http://www.google.com/search?q=civic...ient=firefox-a
Acura http://www.google.com/search?hl=en&c...&aq=f&oq=&aqi=
Old Jun 20, 2009 | 02:01 AM
I know how to use google, thanks.
Old Jun 20, 2009 | 02:41 PM
bump
Old Jun 21, 2009 | 06:16 PM
bump
Old Jun 21, 2009 | 07:09 PM
hey I did not mean it sarcastically. I was hoping one of the topics had your solution. Try reading your code once more. If you did all the recomended fixes to your code 9 perhaps it is being masked by another problem/code.
Old Jun 21, 2009 | 08:02 PM
xrated1's Avatar
how did you set the dizzy becauase that needs to be pointing at specific cylinder
Old Jun 25, 2009 | 11:01 PM
Just a code 9, no other codes. I have gone through all of the things that I have found to cause the problem, as listed above. The distributor is set to whatever stock timing is... 16 degrees I think? Did it with a gun, without a dial.
hondachris1994
May 21, 2015 09:55 PM
88efsedanlx
Dec 10, 2011 05:40 PM
Jimster480
Dec 23, 2009 03:14 PM
Hondamonster
Jul 29, 2007 05:25 PM
caymanjdm97dc2
Jan 26, 2007 04:47 PM
