Which NTK Spark Plugs
Old Sep 28, 2003 | 04:20 PM
7rrivera7's Avatar
Default Which NGK Spark Plugs
I have a built B16a in my CRX and I'm having issues with the plugs not lasting. I am currently using BCPR6ES.
Is this the right plug for an NA which sees weekly strip use? If not, what should be the NTK part number?
What if I want to squeeze a 75 shot? Should I use a colder NTK plug or how about a set of ZEX plugs? Which would be the colder NTK plug number?
Thanks!
Raul
Modified by 7rrivera7 at 6:10 AM 9/30/2003
Old Sep 29, 2003 | 04:03 AM
7rrivera7's Avatar
Default Re: Which NTK Spark Plugs (7rrivera7)
Can someone help me?
Old Sep 29, 2003 | 05:32 AM
TimoneX's Avatar
New User
You mean NGK?
You go up on the # to get a colder plug. For instance ZFR7F is colder than ZFR6F.
Old Sep 29, 2003 | 07:39 AM
976's Avatar
976
New User
Default Re: Which NTK Spark Plugs (TimoneX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimoneX &raquo;</TD></TR><TR><TD CLASS="quote">You mean NGK?
You go up on the # to get a colder plug. For instance ZFR7F is colder than ZFR6F.</TD></TR></TABLE>
NTK is the Japan version of NGK. Both use same materials and everything. The name change has to do with import traffifs and crap... Anyway. You need to go ZFR7F-11! These NGK plugs will solve your problem, esp. with n20.
Old Sep 29, 2003 | 07:53 AM
TimoneX's Avatar
New User
Default Re: Which NTK Spark Plugs (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">NTK is the Japan version of NGK. Both use same materials and everything. The name change has to do with import traffifs and crap... Anyway.</TD></TR></TABLE>
Learn something new everyday. Those are the plugs I'm running currently. Best I've tried thus far.
Old Sep 29, 2003 | 08:10 AM
976's Avatar
976
New User
Learn something new everyday. Those are the plugs I'm running currently. Best I've tried thus far.</TD></TR></TABLE>
Yeah, they handle extreme heat very well..
Old Sep 29, 2003 | 08:17 AM
7rrivera7's Avatar
Hey thanks 976. I'll go get a set today. I can use them for both NA and Nitrous right?
Old Sep 29, 2003 | 08:39 AM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks 976. I'll go get a set today. I can use them for both NA and Nitrous right?</TD></TR></TABLE>
Yup, they all will work for N/A and nitrious, However I recommend the version with 7 for nitrious, and 6 or 5 for N/A.
Old Sep 29, 2003 | 10:04 AM
7rrivera7's Avatar
Last question...
These plugs seem to be made for non-vtec engines. I have a B16a. Should I still use these or BKR6E-N-11
Old Sep 29, 2003 | 10:16 AM
TimoneX's Avatar
New User
Yeah the ZFRs are what's recommended for the B18a/b according to helms. I've used them and BKRs in my GSR and both were fine.
Old Sep 30, 2003 | 04:56 AM
7rrivera7's Avatar
Do you know the difference between BKR6E-11 and BKR6E-N-11?
My local Pep Boys only has the BKR6E-11's
Old Sep 30, 2003 | 10:14 AM
7rrivera7's Avatar
Anyone know the difference?
Old Sep 30, 2003 | 12:55 PM
JimBlake's Avatar
I've got a list that says the N means "special side electrode", but it doesn't say WHAT's so special about it...
kevaccord
May 10, 2007 01:29 PM
zakiu
Honda S2000
17
Apr 23, 2007 09:04 AM
Midori Green
26
Nov 25, 2006 05:39 PM
Calean007
May 9, 2005 07:04 PM
prelude JDM
May 14, 2003 05:17 PM
