NSX Cluster/ VSS Help
Old Jul 26, 2004 | 08:45 AM
freaksandgeeks's Avatar
New User
Default NSX Cluster/ VSS Help
I know that I am going to get a lot of **** for this but this seems to be the best place to ask.
I am looking to put a NSX Cluster in my civic, I know that there is a possiblity for a lot of wiring, but i wanted to know if this is possible. I checked into a s2000 cluster but everthing will work except for the speedo because of a totally different vss setup. Is the nsx vss closer to the s2000 or the integra/civic setup. I know that they are different engines and different trannys and that the nsx is rwd but the s2000 signal i was told is a digital signal and it would most likely never work in a integra/civic. Please help I really like the cluster setup and think that it would be better then doing a all autometer setup.
Please check this out maybe you could even help here
Thanks in advance
email me at sohail@fgstudios.com
tacosandbeans
Jun 17, 2010 09:30 PM
OMG B16
Aug 14, 2009 06:38 PM
djmatix
Mar 27, 2006 10:46 AM
