Nothing left but to TUNE : Help Needed
Old Mar 17, 2003 | 03:32 PM
RABBIT9's Avatar
Default Nothing left but to TUNE : Help Needed
Ok, the engine is almost complete and I've got to figure out how I'm going to tune this car. I don't know whether to go with Hondata, a chipped ECU, or just the standard cam gear/FPR/SAFC.
Here's the set up:
F22B2 SOHC (non-vtec)
Crower rods
Wiseco 11:1 pistons
ACL bearings
balanced rotating assembly
Portflow head with Ferrea valvetrain
WEB camshaft
AEM FPR
AEM Cam Gear
port matched IM
Gude TB
Injen intake
Knology ignition
DC SS header/test pipe/GREDDY EVO exhaust
This engine is going in a 1994 Accord LX AUTOMATIC. I have done the search/re-search/homework thing, and I still don't know which way to go with the engine management. Any advise, pro or con, on any of these options will be greatly appreciated.
Thanks.
[Modified by RABBIT9, 11:47 AM 3/18/2003]
Old Mar 17, 2003 | 03:36 PM
GZERO's Avatar
Default Re: Nothing left but to TUNE : Help Needed (RABBIT9)
Here's the set up:
Crower rods
Wiseco 11:1 pistons
ACL bearings
AEM FPR
AEM Cam Gear
port matched IM
Gude TB
Injen intake
Knology ignition
Thanks.
Read this http://www.accordinglydone.com/forum...=&threadid=466 and i would go with it!
i wanna know about how much power your setup runs after tuned
EDIT: it might not be THE BEST, but it will make the most power out of your car without a 1K plus price
[Modified by GZERO, 7:39 PM 3/17/2003]
Old Mar 18, 2003 | 07:52 AM
RABBIT9's Avatar
Default Re: Nothing left but to TUNE : Help Needed (GZERO)
Thanks for the link!
That looks like something to check into. My only worry when using a chipped ECU is damaging my engine with some F'd up program. It seems to me like the SAFC/Hondata/chipped ECU are all going to cost me about the same ($300 +/-), it's the tuning that's going to get expensive.
Any other ideas/suggestions?
[Modified by RABBIT9, 4:14 PM 3/18/2003]
Old Mar 18, 2003 | 03:12 PM
19924ws's Avatar
Get a chipped ECU from a reputible company. Also degree the cam to make sure it is at TDC when the rest of engine is there. When you do a timing belt job or anytime or mess with the cams and try and put them back on TDC they or it gets a little off +/-. So when you start advancing or retarding cam timing you really don't know where you're starting from. Mike
Old Mar 18, 2003 | 04:57 PM
IN VTEC's Avatar
Rule out Hondata b/c you can't use it with automatics.
Old Mar 19, 2003 | 04:10 AM
RABBIT9's Avatar
Default Re: Nothing left but to TUNE : Help Needed (IN VTEC)
Yes you can use it on automatics, just not the S100 or S200 models, at least according to their web page. I believe the Stage 2/3/4 will work.
Old Mar 19, 2003 | 07:34 AM
GZERO's Avatar
OK, i would say that with the stock ECU chipped would beok, but it's ok if you don't trust me, here are some other things you can look at:
- https://honda-tech.com/zerothread?id=436368
- Vafc (but what about the timming?)
- AEM EMS
- Any other standalones
What would be also a good point is talk to your tuner, the best thing would be to use the standalone he is more comfortable with, at least i would guide myself with that.
BTW: i didn't read any oil cooler in your setup, so i would check this out https://honda-tech.com/zerothread?id=445156
[Modified by GZERO, 11:36 AM 3/19/2003]
Old Mar 19, 2003 | 12:43 PM
RABBIT9's Avatar
Okay, let me tag another question to this thread.
The local tuner (the only one I'm aware of) just went belly up. Does anyone have contact information for a good tuner in the central Georgia/South Carolina area? GZERO makes a good point. Maybe I should just woory about finding a good tuner first, and go with whatever system he's best at tuning.
ridin98civic
Nov 1, 2006 11:20 AM
Basically
Sep 27, 2005 06:41 PM
00gsrvtec
Apr 27, 2005 06:13 PM
fibercarbon
Jun 16, 2004 05:25 PM
