not a honda question
my fiero's fuel injector wont send gas into the throttle body....i took apart the throttle body and cleaned it all up. put it back together and it still didnt spray n e gas. my fuel pump is working and im getting pressure to the throttle body but just my injector wont spray.
some ppl say tht my distibutor has three notches that every time they hit the injector should spray. is this true? or that my ECU is messed up r something. car has been sittin and i need it to run like right now so the fastest advice i could get i would really appreciate it alot
Pontiac Fiero 2.5L
Pontiac Fiero 2.5L
You should find a pontiac forum. Here's one I found.
http://www.automotiveforums.co...f=768
Get a noid light and plug it into the injector harness and crank the engine over. If the light flashes you're getting signal and are either not getting fuel or you have a bad injector.
adamsjm5
Nov 20, 2006 04:22 PM
