Not Hitting VTEC, Please help!
Old Sep 24, 2003 | 05:16 PM
Import RP's Avatar
Default Not Hitting VTEC, Please help!
Alright, I have 4th gen prelude with an H22A1 motor. I am having two problems. If anyone can be of any help, that would be GREAT!
1) The speedo isn't working and it throws the speedo engine code.
2) Not hitting vtec and hitting the rev limiter at 6.5k rpm's.
I am pretty sure those two problems are unrelated. VTEC and normal engine rev limiting were working after the speedo broke. I am pretty sure I know how to fix the speedo sensor. But what about the VTEC, low rev problem??? What could possibly be wrong? Any opinions would be awesome!!
Thanks in advance,
Jeff
Old Sep 24, 2003 | 06:01 PM
93VAhatch's Avatar
Default Re: Not Hitting VTEC, Please help! (Pyrochaos38)
Sounds like your ECU may be running in a safe mode, to keep from causing other problems.
Old Sep 24, 2003 | 06:11 PM
Import RP's Avatar
Default Re: Not Hitting VTEC, Please help! (93VAhatch)
What should I do to fix this? Re-set the ECU or what?
Old Sep 24, 2003 | 08:11 PM
Import RP's Avatar
Anybody?
Old Sep 24, 2003 | 09:00 PM
VTECorona's Avatar
Reset it and see if it throws a code.
Old Sep 24, 2003 | 10:25 PM
Mochanic's Avatar
VTEC will not work when some codes are present.
Fix your speed, and it will probably work again... look very carefully at the speed sensor and connector on the tranny.
Old Sep 24, 2003 | 11:11 PM
FastEK9's Avatar
Default Re: Not Hitting VTEC, Please help! (Mochanic)
Well the Ecu has to detect MPH in order for it to engage Vtec, so in other words if your speedo does not work u will not have vtec.
Old Sep 24, 2003 | 11:21 PM
mmuller's Avatar
Mad Scientist
Default Re: Not Hitting VTEC, Please help! (FastEK9)
no vss=no vtec
stehigs321
15
Mar 1, 2019 05:16 PM
B16 CRX
64
Jul 23, 2004 10:06 AM
SupaFly_Honda
Oct 8, 2003 07:00 PM
Import RP
Sep 25, 2003 06:58 PM
90_Civic_Hatch
Sep 20, 2002 07:08 PM
