noob question
Old Mar 30, 2006 | 08:02 PM
tor-scot's Avatar
Default noob question
i looked around but its hard for me to find something that i dont even know the correct name, so maybe you can help me. i recently cut my valve cover to expose those high end oem cam gears, but since i did its almost like the car got noisier. when the hood is up i can hear the belt hitting something, what is the name of that belt? and when should it be replaced, id kind of like to replace it before it slips and its bye bye motor, can anyone help me?
Old Mar 31, 2006 | 12:25 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: noob question (tor-scot)
First, that cover is there for a reason. To keep debris from falling into the timing belt area and chewing up the belt. (Trust me its happened to me before). Second, maybe something did fall down in there. You didn't cut the cover with it on the car or something did you?
Old Mar 31, 2006 | 03:50 AM
tor-scot's Avatar
nope, i took it off to cut it, cleaned it thoroughly to before putting it back on, im just wondering if the belt has seen its day, and needs to be replaced.
Old Mar 31, 2006 | 05:08 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what is the name of that belt?</TD></TR></TABLE>
Uhhh... A timing belt?
Old Mar 31, 2006 | 05:27 AM
tor-scot's Avatar
this is what i thought, just wanted to make sure. so when do you know when its time to be replaced? i can see the seem go around, but its almost like there a frey in the belt also that goes around.
Old Apr 1, 2006 | 03:53 PM
B18C_EJ8's Avatar
If the belt is worn and frayed then you shouldn't need a response on the forum to tell you to replace it... Worn timing belts = belt failure = catastrophic engine damage.
Get it changed ASAP.
misha
11
Nov 5, 2006 01:01 PM
MassCivicMan987
Jul 3, 2006 04:25 PM
crx_88_si
Jun 30, 2005 09:02 AM
LudeyKrus
Sep 3, 2004 11:22 AM
mrxracing
May 26, 2004 08:20 PM
