Noob needs some help!!
Old Mar 27, 2004 | 12:41 PM
getzy3's Avatar
Default Noob needs some help!!
Whats up guys?? I am in the planning out a motor for a drag car that i am gonna build up. It is gonna be for the track but must be streetable for the weekends. I am gonna do a complete buildup, from bare block up. I need some help deiciding what all to go w/ so if anyone here builds motors leave your email. i need someone that is serious and actuallyknows what they are talking about. I have had one heck of time finding some help and was recommeded here. So leave your email if you would and i'll contact you. Thanks
Old Mar 27, 2004 | 01:55 PM
Kal's Avatar
Kal
Default Re: Noob needs some help!! (getzy3)
what type build and what engine? you gotta post more info than that.
Old Mar 27, 2004 | 03:17 PM
getzy3's Avatar
Default Re: Noob needs some help!! (Kal)
B18c1 thats gonna be built from bare block up, sleeves, maybe bored to a 2.0 and turbocharged. not sure what car it is going in, i just wanna build up a motor first.
Old Mar 28, 2004 | 04:23 AM
TimoneX's Avatar
New User
You should determine what your budget will be and whether you're looking to stay NA or definately looking to boost. If you're looking for a serious NA build then you probably want to sleeve and bore to 85+mm. If you're sure you'll boost it then the displacement won't mean very much and would just unnecessarily weaken the cylinder walls. You should run this by the FI junkies if you haven't already.
Old Mar 28, 2004 | 07:27 AM
Kal's Avatar
Kal
Default Re: Noob needs some help!! (TimoneX)
yep, seriously what type of budget are you on... there are many possibilities with the right amount of money and there are adequate ones for a budget. It all depends on how much you have. and yep, boosting + addition displacement isn't all that necessary.
Old Mar 28, 2004 | 04:10 PM
getzy3's Avatar
i need a whole swap (everything to make motor run, motor, and tranny) plus i wanna build up the block and add a turbo. No turbo kit though since i can put one together a hell of a lot cheaper. I have $6000 to work with. Is it possible??
Old Mar 28, 2004 | 04:54 PM
Kal's Avatar
Kal
6000 only?
no
edit:
because - boosting requires a lot of attention and long term maintenance...plus parts are expensive especially internals and engine management
Old Mar 28, 2004 | 05:20 PM
pb16b's Avatar
save money... can't build with 6000
Old Mar 28, 2004 | 06:08 PM
getzy3's Avatar
Default Re: (pb16b)
would ls/vtec be cheaper?? My main goal is to run 12's. Can i do that w/ 6 grand??
Old Mar 29, 2004 | 02:11 PM
getzy3's Avatar
Default Re: (getzy3)
ok I'm gonna turbo and Ls with stock bottom end. I am gonna run hondata for tuning. Is it possible to run 12's with a stock block??
MrParks
Oct 26, 2006 10:45 AM
Ckjeepin
Dec 15, 2005 07:09 AM
boostdriven
Jun 8, 2004 01:29 AM
1.8T_EG
Nov 27, 2002 11:38 AM
gcajnr21
Aug 4, 2002 06:23 PM
