noise while reving
Old Jul 8, 2004 | 11:42 AM
blkvtec's Avatar
Default noise while reving
everytime i rev at like 3000 rpm, i hear this grinding noise..i am unable to tell wher eexactly its coming from but it sounds like from the bottom of the car. i have a 2000 civic si with 48000 miles.
Old Jul 8, 2004 | 12:33 PM
draglv104's Avatar
Default Re: noise while reving (blkvtec)
I had a GSR with the exact same problem. I couldn't figure it out for the life of me. Please, in detail. describe this noise the best you can and perhaps I can help you.
Kyle
B.S. Biochemistry/Cellular Molecular biology/Biophysics
Synthesis of Potassium bis(2-hydroxyethyl)dithiocarbamate
Retired master mechanic
Old Jul 8, 2004 | 12:34 PM
draglv104's Avatar
Default Re: noise while reving (draglv104)
excuxe the . where there was supposed to be a ,
Old Jul 9, 2004 | 08:40 AM
blkvtec's Avatar
it sounds like a scraping noise..could it possibly be that exactly at 3000 rpm my flywheel its catching? any help?
Old Jul 9, 2004 | 10:16 AM
JimBlake's Avatar
First I suppose you can check all your exhaust heat shields, just to eliminate that as a possibility. Mounting hardware rusts & falls apart, then the shields buzz & rattle against each other & against the exhaust pipe. Crawl under & start banging stuff with your fist until you find something loose.
Then maybe it's the famous buzzing A-pipe. I don't know about the SI, but for the GSR it's like this... The A-pipe (from exhaust manifold, under oilpan, to cat) is really a pipe-inside-a-pipe. It either warps a bit or comes loose, then the inner pipe buzzes against the outer one. That A-pipe is real expensive so it's a good excuse to buy a header.
Old Jul 9, 2004 | 11:37 AM
EliteCivicX's Avatar
never heard of this before but it sounds to me like it could be the header or exhaust or the exhaust manifold if u still have one.
oO-SIX-Oo
May 26, 2010 04:36 PM
gohonda
Oct 15, 2007 03:48 PM
crzyfool24
Dec 3, 2003 05:00 PM
kethdredd
Feb 5, 2003 07:42 PM
