no vtec, no code.....
Old Jan 18, 2007 | 08:04 PM
93sidelsolvtec's Avatar
Default no vtec, no code, wiring correct, has oil.....
90 accord with h22. P28 ecu
vtec wired correctly... 100% sure on it.
No vtec. only code is "code 3". Im replacing Map sensor asap.
What would make vtec not work? where do I start? havent seen this before unless wires are unplugged.
Modified by 93sidelsolvtec at 9:50 PM 1/19/2007
Old Jan 19, 2007 | 06:56 AM
b16a4's Avatar
Default Re: no vtec, no code..... (93sidelsolvtec)
oil pressure
make sure its topped up
Old Jan 19, 2007 | 08:49 PM
Its got oil. I even checked with another H22 dip stick to make sure.
Could the map sensor being bad make this happen? The map got bumped and now it wont work. I have a brand new one on the way.
If the VTEC solenoid is bad will it ALWAYS throw codes 22 or 21, or can it fail and not throw a code? Anyone hear of this?
I read in a old thread from 2004 that some was having a code 22 and another members advice was maybe a blocked oil passageway??
Modified by 93sidelsolvtec at 10:01 PM 1/19/2007
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
ZC DOHC CRX
May 20, 2009 10:52 PM
ef-hatchcrap
Feb 21, 2009 05:10 AM
gotslicks
Nov 26, 2006 03:44 AM
