ELECTRICAL HELP PLZ!
Old Dec 13, 2007 | 12:51 PM
KraziCivicSi's Avatar
Default ELECTRICAL HELP PLZ!
I have a 89 dx civic with a b18a1 swap. it has been converted to mpfi. I cant get power to my ecu. The plugs were cut to hell and back so i went and purchased uncut plugs and replaced them. I have also gone thru 3 harnesses. No matter what i try, there is never any power to the ECU. I have checked voltage with a voltometer, there is power going to the ecu, but it wont power on. I have checked grounds, re-ran ground, and double checked everything I dont know how many times. I had this same problem when i had my b16 in the car. I seriously need some help. I have searched every site imaginable. Is there a way to run a power and ground to the ecu other than thru the main relay. Some one please help. Thanks
Old Dec 13, 2007 | 02:10 PM
pgpbubble's Avatar
Default Re: ELECTRICAL HELP PLZ! (KraziCivicSi)
Is it a known working ecu? Have you sure you verified all your known grounds?
Old Dec 13, 2007 | 05:10 PM
Default Re: ELECTRICAL HELP PLZ! (pgpbubble)
ecu works in my buddy's crx. i have checked every ground to my knowledge.
Old Dec 14, 2007 | 07:09 PM
Man im gettin frustrated with this freakin car. Still not getting power to the ecu! i re-ran grounds, thicker wire for both power AND grounds checked everything. only now, when i cut the car on, the starter doesnt engage. after i turn the car off, the car stays on (as far as the the "idiot lights" like oil light, battery light, ect) its wierd. everything is gettin power. i have more than enough grounds (so i think) anyone have any suggestions? i really need help bad
Old Dec 14, 2007 | 10:04 PM
bump
Old Dec 15, 2007 | 04:56 PM
bump
i would really like some advice. anyone else ever had this happen?
Old Dec 21, 2007 | 10:31 AM
super bump
Old Dec 22, 2007 | 08:24 PM
zuum's Avatar
OMG... your screwed man... sounds to me like you Fd up your under-dash harness, buy a new one and start over, this time use a jumper harness... you main relay was probably bad and that probably it, you may have even screwed up your engine harness... no way to diagnose these kinds a of problems over the internet you've got a lot going on there.
Old Dec 22, 2007 | 10:07 PM
Default Re: ELECTRICAL HELP PLZ! (zuum)
sad part about it is... thats what i have been thinking the whole time. i think the bastards that i paid to do my car screwed it up. Half assed shops are FTL
civicmulisha
10
Dec 26, 2009 10:56 AM
KraziCivicSi
Dec 13, 2007 05:08 PM
MrMayhem
Nov 22, 2005 07:54 PM
mockujin
Nov 14, 2002 07:43 PM
