No trouble codes
Old Aug 14, 2002 | 10:58 AM
Malgerus's Avatar
Default No trouble codes
well, stupid car still won't start... and on top of that, I unplugged the MAP sensor, TPS, and the 02 sensor, and I can't even get it to throw a code! Any reason for this??
Old Aug 14, 2002 | 12:44 PM
Malgerus's Avatar
Default Re: No trouble codes (89_Y_49)
c'mon help!
Old Aug 14, 2002 | 12:49 PM
Spade's Avatar
Does the engine light stay on?
Does it ever turn on?
Old Aug 14, 2002 | 02:03 PM
Malgerus's Avatar
Default Re: No trouble codes (Spade)
The check engine light does not stay on unless I jump the connector, and when I do that it doesn't flash any codes, just stays solid.
[Modified by 89_Y_49, 11:04 PM 8/14/2002]
Old Aug 14, 2002 | 03:29 PM
Chiovnidca's Avatar
Does it come on for 2 seconds and then go out when you turn your ignition switch to run?
Old Aug 14, 2002 | 10:49 PM
raene's Avatar
Default Re: No trouble codes (Chiovnidca)
yeah it does that... we finally got a code by unplugging the VTEC solenoid. I wonder why it isn't throwing a code for the other sensors?
Old Aug 15, 2002 | 02:36 AM
kinesistech's Avatar
Default Re: No trouble codes (raene)
The code came because it expects to see a certain resistance and you took it. Does the car even crank? You said the car doesnt start and there is no code.
Inducing a faults wont help it start. Id like to help more but I need more details.
Old Aug 15, 2002 | 07:06 AM
Malgerus's Avatar
Default Re: No trouble codes (kinesistech)
well, the car cranks over fine, but it just refuses to start. it has spark, fuel, air, and I did a compression test - all fine. I just thought it was funny that I would get no codes from unplugging all this stuff, cranking it over, and still get no codes.
90R3x
Dec 16, 2014 09:10 AM
Eg6_LsR
Oct 14, 2005 06:27 PM
EK_vzla
Oct 8, 2003 11:20 AM
95sihb
Nov 14, 2002 05:28 AM
Leets
Mar 25, 2002 08:41 PM
