No temp gauge "cel 6/bad ect"
Old Feb 18, 2011 | 05:04 PM
sc34dc4's Avatar
Default No temp gauge "cel 6/bad ect"
I just finished my gsr swap and my temp gauge isn't working at all. The head didn't come with a ect sensor so I used the one out of my old ls which I know was working just fine before the motor was pulled. I also swapped the ect sending unit from my ls tonight just in case since I know it was good. I was getting cel 6 when I jump the plug but now it's cleared and isn't back yet. If I un plug the ect sensor the car revs up and the CEL becomes solid. If I unplug the sending unit nothing happens. If I use a test light attached to the positive terminal and check the metal connector on the ect sending unit. The light does come on but it's very faint. So this tells me it's getting a signal through the wire. It doesn't seem like it's a strong signal since the light is very faint. If I test the ect sensor it self. The light is very bright. I'm gonna pick up an ect sensor from the junk yard if I can find any hondas with the motors left in them but I know that's not it at all. Anyone else have any ideas of what it could be since I already swapped out both sensors? The fan is working fine and both rad hoses get warmed up so I'm not super worried but I'd like to get it figured out soon since I'm trying to go get tuned here in about a month.
Old Feb 18, 2011 | 06:42 PM
night's Avatar
Default Re: No temp gauge "cel 6/bad ect"
wait, what?
the ECT is ecu only.
the sender is gauge only.
unplug the single wire bullet connector sender and use a piece of wire to jump it straight to ground. if the gauge goes all the way to hot it is ok.
Old Feb 18, 2011 | 06:47 PM
sc34dc4's Avatar
Originally Posted by night
wait, what?
I unplugged the single wire connector and ran a wire from the negative on the battery to the end of the bullet connector and nothing happened. The gauge stayed on cold.
So what's my next step? Could I run a wire from that single pin connector to the back of my gauge cluster plugs and splice in there to bypass the wire and see if that does anything?
Old Feb 18, 2011 | 07:12 PM
sc34dc4's Avatar
I don't know I've had enough for tonight. I'm going to the bar to drink my sorrows away lol.
Old Feb 18, 2011 | 07:38 PM
night's Avatar
yes you should do that to rule out a broke wire. find a wiring diagram and directly off the cluster do the same thing. jump it to ground.
Old Feb 18, 2011 | 10:16 PM
sc34dc4's Avatar
Yeah I'll pull out the helms manual and trace it down. If it does go straight to hot then I know the wire is broke. I'll just run a new one into the bay and put a new connector on it. Call it a day. If that's not it then I have no freaking clue what is causing it.
I don't think this has anything to do with the problem but I'm running an obd-1 LS harness on a gsr.
Old Feb 19, 2011 | 10:58 AM
sc34dc4's Avatar
Picked up a new water temp sensor today from advance just to try it out. I know it's probably not going to fix anything but it's worth a shot. Also going to borrow my friends chipped P28 and but my crome chip in it and see if it changes anything.
Old Feb 20, 2011 | 01:15 PM
sc34dc4's Avatar
night - I jumped it straight from the back of the cluster to ground and the gauge still didn't move at all.
Old Feb 23, 2011 | 01:34 PM
sc34dc4's Avatar
Would possibly swapping out the ecu eliminate a problem? Someone said something about burning up q31 or some place on the board.
Old Feb 23, 2011 | 01:38 PM
night's Avatar
well, u gotta make sure that individual gauge is getting power, and other than that it has to be the cluster.
Old Feb 23, 2011 | 01:51 PM
sc34dc4's Avatar
I installed the ls temp gauge into my gsr cluster tonight just for ***** and giggles and everything is working now. Don't ask me since the Ls cluster is the one that wasn't working to begin with. Oh well IDK anymore cause it's fixed. Finally!
Old May 15, 2011 | 09:08 AM
Swervin95EX's Avatar
Im having the same problem as you with my LS/Vtec swap.. I have an integra dash in my 94 civic hatch... Di you try running a single wire from the sending unit to the cluster? If so did it work that way... Im thinking i have a bad wire, cause the car came with a chasebays harness tuck.
ramboPandA
Nov 27, 2014 12:09 PM
Civic Racer X 7
Aug 15, 2014 07:35 PM
BlackShingo
May 20, 2010 07:36 AM
Dreamw3rkz
Sep 29, 2008 02:08 PM
TcUiRvBiOc
May 26, 2007 03:41 PM
