No power in my type r
Old Jun 18, 2002 | 04:59 AM
turbodsmpower's Avatar
Default No power in my type r
Hay everyone this is my first post on this site having trouble w/ this car and wonder if anyone know the answer.
When i look at the car on diagnostic tool the vtec selonoid stays on at idle that looks fine, but the pressure switch is on at idle as well and when the car is driven the vtec pressure switch turns off when vtec kicks in is this right?
Old Jun 18, 2002 | 06:31 AM
Spade's Avatar
Default Re: No power in my type r (turbodsmpower)
Not sure, what codes is the car throwing?
Old Jun 19, 2002 | 02:53 AM
pulled the check engine light and it appears to deteroating catalytic converter. The car has jdm 4-1 header aem cold air intake and exhaust. Went to the dyno and it didnt put down more than 127 ATW I knew something was wrong but do you think it will yeild like 30 horsepower just from the cat being clogged. I have a cat on order and will be in tuesday. Anything else you might think it is
Old Jun 20, 2002 | 03:19 PM
1.7na's Avatar
turbodsmpower
If it is your cat converter, you will see much better numbers with the new
cat. I gain back 22whp when I swapped my bad cat out with a straight pipe.
You car should be in the 165-170ish whp range. Keep us posted!
good luck!
1.7NA
Old Jun 20, 2002 | 03:30 PM
Kamin's Avatar
Default Re: No power in my type r (1.7na)
turbodsmpower
good luck!
1.7NA
huh?
its possible that its your cat, replace it and see.
Old Jun 20, 2002 | 10:11 PM
1.7na's Avatar
Default Re: No power in my type r (KAMiN)
turbodsmpower
I didn't believe I lost that much with a bad cat myself until I seen my dyno results.
Old Jun 20, 2002 | 10:49 PM
Unsung's Avatar
I've seen it happen to 2 of my friends, running too rich and clogging the cat and losing tremendous amounts of power.
Old Jun 21, 2002 | 07:31 AM
1.7na's Avatar
Default Re: No power in my type r (JDM B-Series)
JDM B-Series
Did you friends have stock cats or a aftermarket cat? I just ordered a carsound 94006 ( trying to stop running the straight pipe on the streets) and was wondering if they are prone to clog up or getting blown out.
1.7NA
Old Jun 26, 2002 | 03:43 AM
WOW that is something ill be looking forward to Im getting the cat installed today and taking it to the track to see if it improves i know it will. Ill keep you posted on what happens. thnks for the info
Old Jun 26, 2002 | 09:22 AM
willydawsonv's Avatar
Now I really want to know the results cuz I have a 00 civic ex SOHC V-tec with custom CAI DC sport 4-2,2-1 header, and just resently my car started running like s***, well within the last couple of months, but it's getting much worst even with the header, I'm still runnin stock exhaust, do you think it would be a bad idea to hollow out the cat? Do you think it will disturb the O2 sensor that is mounted right on top of the cat?
[Modified by willydawsonv, 6:25 PM 6/26/2002]
Old Jun 28, 2002 | 04:33 AM
Default Re: No power in my type r (willydawsonv)
Good news my buddy went and had the cat cut out of the car and man does it feel strong now. We went racing last night and were smoking cars left and right. the cat was definetly the problem
Old Jun 28, 2002 | 01:50 PM
1.7na's Avatar
Old Jun 28, 2002 | 04:45 PM
I agree, I had the same problem, and I just hollowed out my car yesterday, and that was all it took to get the power back, but something else is wrong, I've been throwin a code for about a week
I think it might be an o2 sensor, but damn if I know.
[Modified by willydawsonv, 1:46 AM 6/29/2002]
Old Jul 9, 2002 | 04:06 AM
well everyone the type r went to the dyno pulled 170 atw by taking the cat off. Started off w/ 127 prior to the cat. It must have been clogged up pretty bad. w/ only three pulls on the aem computer the car made another 8 hp. It still has room for more tuning.
E46Kid
Mar 20, 2020 09:52 AM
33steviebix
10
Oct 30, 2011 08:49 AM
DB1_559
Apr 30, 2009 10:45 PM
ah789454
Sep 11, 2006 02:13 PM
HT Chaplain
Sep 19, 2004 03:34 AM
