No power to ECU on swap
Old Mar 15, 2003 | 07:19 PM
  #26
raene's Avatar
Default Re: No power to ECU on swap (eg6ajk)
WHOA MOMMA I just got the ECU to have power!
There was a chunk of wire chopped out on the ignition circuit - about 6" of the thick black/yellow wire was missing. I was checking the Helms CRX Workshop manual in the hopes of finding that missing inertia switch, and I came across a diagram showing how to test the ignition circuit. I figured what the hell, why not test it, since we just got done replacing the lock cylinder (swapped his non-tilt column for a CRX Si tilt column). The first few tests went fine, then bing - no continuity on a major wire, so I checked it, added in a wire where the original was cut, and voila! Makin' me happy mang
Now the fuel pump's not turning on... *sigh* back to the drawing board... at least this should be hella easier!
B20VSi2000
Aug 19, 2016 12:43 PM
civicmulisha
10
Dec 26, 2009 10:56 AM
vtecnition
Sep 6, 2005 09:42 PM
PGT Driver
Jan 15, 2005 11:09 AM
KevronsEG
Apr 21, 2002 01:49 PM
