nitrous tech.
Old Jan 26, 2002 | 07:47 AM
2SLO's Avatar
Default nitrous tech.
help me out here. last time i had my dry nitrous kit on, i blew my head gasket. it was only a 60 shot. yes i used it alot in one night but can someone tell me how far away from the TB the nozzel should be cause i think thats what caused it. thanks
Old Jan 26, 2002 | 08:04 AM
non-VTEC's Avatar
Default Re: nitrous tech. (2SLO)
8-10" away from the T/B
if you have it further away it might be even better since it will evenly distribute to all 4 cylinders.
Old Jan 26, 2002 | 08:06 AM
2SLO's Avatar
Default Re: nitrous tech. (non-VTEC)
thanks man. yeah youre right, i think it all went straight back to the farthest cylinder (4? maybe 1) and went to poo poo from there. thanks for the help!
Old Jan 26, 2002 | 09:57 AM
integra0260's Avatar
New User
For dry NOS kits I recommend about 10 to 12 inches away from the throttle body because this will let the NOS distrubte easier to all 4 cylinders. For wet kits I recommend you place the fogger no further then 5 inches away from the throttle body because you are mixing fuel along with the NOS. If its stuck too far away you have a chance to freeze the throttle plate open and also if the fogger is too far away you actuall get more NOS then fuel, an uneven mixture which will lead to detonation.
Old Jan 26, 2002 | 11:55 AM
Kataku2K3's Avatar
Default Re: nitrous tech. (integra0260)
I try to place a dry kit between 12 and 18 inches away from the throttle body. Only bad side of it is it's take a couple seconds for the nitrous to hit. It seems to disburse of the nitrous well tho.
Old Jan 28, 2002 | 04:46 AM
Mista Bone's Avatar
D Tranny Guru
ZEX kit with nozzle 16-18" away from TB plate.
Must be doing something right, 13.5 on a SOHC.
Slowboy!
Feb 3, 2006 07:56 PM
allshownogo7
Feb 27, 2002 07:05 AM
redteg1
Jan 4, 2002 09:12 PM
Duck Sauce
Dec 16, 2001 10:35 PM
