nitrous with high compression?
Old Nov 6, 2002 | 03:12 PM
Cow's Avatar
Cow
Default nitrous with high compression?
I'm probably going to do a mild N/A setup with raised compression (JDM b16 or CTR pistons, so 11.6:1 or 12:1) and CTR cams, with Hondata tuning. Could I run a small wet shot (<50) with this setup or would I have to use forged pistons with this kind of compression? What about the overlap? Too much? Any info is appreciated.
This is in a b18c1 btw.
Old Nov 6, 2002 | 04:27 PM
TREVER's Avatar
Default Re: nitrous with high compression? (Cow)
I run a 120 shot on 11.2 cr. A 50 is no prob on your set up
Old Nov 6, 2002 | 05:40 PM
sweet's Avatar
Default Re: nitrous with high compression? (TREVER)
should be no problem with enough fuel and the proper ignition timing. just get it tuned. the CTR pistons are nice but may not hold up for a long time with a high C/R and N2O. then again with tuning the motor may last a long time.
N2O works well with higher C/R's. the fuel delivery and ignition tuning is important. if you don't have a higher flowing fuel pump already then i suggest getting one as well as a stronger ignition system for increased spark.
BTW i'm currently running 125 shot with 11:1 C/R on 93 octane fuel and no real tuning to date. thought the motor is fully built, a B18C.
01-DC2R
Mar 22, 2008 09:46 AM
lke2drvgsr
29
Dec 7, 2003 08:53 AM
BME1986
Nov 17, 2003 12:38 PM
Austin
Jul 10, 2001 08:28 AM
