Nitrogen filled tires???
Old Sep 3, 2005 | 08:22 PM
RynoDyno312's Avatar
Default Nitrogen filled tires???
Well, I got a new car and the previous owner said he filled the tires with nitrogen. Is it alright to fill tehm with air the next time they need it, ot should I stick with the nitrogen? Thanks.
Old Sep 3, 2005 | 08:46 PM
RedlinedVTEC's Avatar
Default Re: Nitrogen filled tires??? (RynoDyno312)
From what I've read the advantage to using nitrogen is it is moisture free so you won't experience fluctuations in tire pressure with temperature changes.
Old Sep 3, 2005 | 09:24 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Nitrogen filled tires??? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">From what I've read the advantage to using nitrogen is it is moisture free so you won't experience fluctuations in tire pressure with temperature changes.</TD></TR></TABLE>
that is correct i am a jet mechanic and we service teh tires with nitroen due to teh fact teh teh pressure will not fluctuate as well as not have moisture build up as well.....is it worth it on a street car...no it isnt.... jsut use good ol COmpressor air
Old Sep 3, 2005 | 09:57 PM
Combustion Contraption's Avatar
Whats up with all the 'teh' tonite, snoflake?
Old Sep 4, 2005 | 07:39 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Whats up with all the 'teh' tonite, snoflake?</TD></TR></TABLE>
i type too fast for the computer sometimes thats all LOL
Old Sep 4, 2005 | 02:40 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RynoDyno312 &raquo;</TD></TR><TR><TD CLASS="quote">Well, I got a new car and the previous owner said he filled the tires with nitrogen. </TD></TR></TABLE>
I prefer an 80% nitrogen mix, it's alot cheaper.
Old Sep 4, 2005 | 05:09 PM
Dogginator's Avatar
Daisy... Daisy...
It doesn't matter. The real advantage of N2 inflation is to reduce oxidation of the cord-rubber bond in the tire carcass when the gas leaks past the inner liner.
Old Sep 8, 2005 | 11:44 AM
al3e's Avatar
Default Re: Nitrogen filled tires??? (Dogginator)
<FONT SIZE="10">what about increasing the mpg in your car... since air is heavier than nitrogen... save a few pounds????</FONT> or is it?
Old Sep 8, 2005 | 12:24 PM
Lewdin' Incognito's Avatar
Default Re: Nitrogen filled tires??? (al3e)
Um....air is 80% nitrogen. How would Nitrogen be lighter than itself?
Btw, using 100pt font doesn't make your ideas any better....
Old Sep 9, 2005 | 06:40 AM
amckee's Avatar
All gasses increase pressure with an increase in temp. Nitrogen is not imune to this. Aircraft use nitrogen to decrease the chances of fire when a tire blows. But, it does sound cool to say my tires are inflated with nitrogen.
Old Sep 9, 2005 | 09:58 AM
per4mance's Avatar
Default Re: Nitrogen filled tires??? (amckee)
alot of round track people do it, to keep the tire pressure from rising and causing the car to get loose, halfway threw the race.O and i am talking about 1/4,3/8,and 1/4 mile tracks, were you don't have pit stops.But as far as everyday use, i don't know how it would act on an everyday basis.
Old Sep 9, 2005 | 01:04 PM
Crazydave's Avatar
Default Re: Nitrogen filled tires??? (per4mance)
Maybe you should fill your tires with helium!
Lithel
Feb 26, 2008 02:38 PM
Silencer1503
Sep 13, 2007 10:08 AM
PatrickGSR94
Jul 5, 2007 07:26 AM
LoganMantits
May 20, 2005 02:52 AM
cbstd
17
Dec 24, 2004 03:01 PM
