NEW CLUTCH PROBLEM> its the right clutch wrong flywheel?
Old May 11, 2004 | 09:10 PM
dElSleepiE's Avatar
Default NEW CLUTCH PROBLEM> its the right clutch wrong flywheel?
hi.. the problem is i just ordered a clutch for my del slo. but the pressure plate wont line up perfect with the dowls 1 will go in and the other 2 will be off a little. could this be because i have a gsr flywheel or is there a difference. it says p30 on the flywheel but the pressure plate box says p72/p73? i didnt think there was a difference in the b series flywheels.. ??
Old May 11, 2004 | 10:11 PM
triggerX's Avatar
Default Re: NEW CLUTCH PROBLEM> its the right clutch wrong flywheel? (_ApplePoop_)
You have a b series motor in your tranny? If so then they should line up. Did your clutch kit come with a clutch disc and pressure plate aligning tool? If not then you'll have to go to the local auto parts store and buy it. This tool will perfectly align your clutch discs and pressure plate for proper installation.
CorrodeONE
Jun 6, 2008 11:45 PM
zerovandez
Mar 10, 2007 11:08 AM
h8ted ek
Dec 22, 2006 07:41 PM
DPSJosh
Aug 26, 2005 06:09 AM
-[95cxhatch]-
Mar 1, 2004 01:22 PM
