new cams,but i got a vtec problem
Old Mar 8, 2005 | 06:05 PM
kidrolla's Avatar
Default new cams,but i got a vtec problem
ok here the deal i have a b16a GEN1.replaced the cams springs and retianers all skunk 2 and the cams are stage 1.got everthing in going and i dont know if its cause we took the vtec off and its got to refill but i have a chipped ecu and it kicks in at 4800 and if i hold it say at 5200 and it starts to cut out or sputtering,but if im on it and it seems fine. could it be a fuel problem or what.
Old Mar 8, 2005 | 08:20 PM
Redline130's Avatar
Default Re: new cams,but i got a vtec problem (kidrolla)
I'm having a hard time understanding your post, but I'll try my best to help you out here. Did you check your timing after everything was reassembled? Are both cams in time with each other? Check engine light by chance? What kind of chip is in the ecu?
Old Mar 9, 2005 | 03:10 PM
kidrolla's Avatar
Default Re: new cams,but i got a vtec problem (Redline130)
everything is in time and i have a spoon chipped ecu and it did fine on the stock stuff,but we change the cams springs and retainers out.we got it all back in and when i drive it its fine but when vtec kicks on and say i hold it at steady at 5000rpms it kind of misses or seems like its geting to much fuel.but if im on it ,it runs fine.
Old Mar 9, 2005 | 03:55 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
After I replaced my Lost motion assembies,my car acted
really weird the first time or two the vtec engauged..
I would guess it had lost oil from the circuit..
I figured I had screwed something up but so there after
it acted normal again..
Old Mar 9, 2005 | 05:06 PM
kidrolla's Avatar
Default Re: new cams,but i got a vtec problem (88DXCRX)
so i got to get the oil back into the vtec and ive hit vtec few times in the last few days
Old Mar 10, 2005 | 07:52 AM
Redline130's Avatar
Have you replaced the cap and rotor? Plugs good?
Old Mar 12, 2005 | 03:32 PM
kidrolla's Avatar
it runs fine till it hits vtec and it will only mess up when i hold it about 5000 rpms
kikoy
13
Apr 13, 2006 09:01 AM
RiSiNgDc2
Mar 11, 2006 09:08 PM
rcjoe
May 21, 2004 11:43 AM
12secLSvtec
11
May 20, 2004 12:04 PM
Leo95SE
Aug 10, 2001 01:26 PM
