need tranny help
Old May 11, 2004 | 04:38 PM
RACESMART's Avatar
Default need tranny help - UPDATE
ok here is the deal, i started to have some tranny problems a few months ago, 2nd gear syncros were bad and when at a stop light it was hard to shif into 1st.i replaced the syncros and that fixed one problem, evrone said i needed a new clutch to fix the 1st gear problem, so i replace ithe clutch with a new clutch masters stage 4 and cltch masters flywheel,still hard to shift into 1st ,any ideas? shifts into gear no problem with car off.
could it pssibly be associated with my shif linkage,? ths shifter it self? dc sports
i replaced the shif linkage, didnt work though, did make the rest of the gears shift smoother,im going to replace the 1st gears next week, ill see if that worksModified by RACESMART at 4:18 PM 5/14/2004
Modified by RACESMART at 3:00 PM 5/22/2004
Old May 13, 2004 | 11:54 AM
RACESMART's Avatar
Default Re: need tranny help (RACESMART)
TTT
Old May 13, 2004 | 04:54 PM
RACESMART's Avatar
Old May 13, 2004 | 05:14 PM
doublejz's Avatar
master cylinder, slave cylinder, did you replace just the 2nd gear sychros or 1st too,
Old May 13, 2004 | 06:06 PM
limpy's Avatar
Default Re: need tranny help (doublejz)
try replacing the maininput shaft bearings too. it will help everything shift alot smoother.
Old May 13, 2004 | 06:53 PM
RACESMART's Avatar
DID 1ST ALSO,1ST AND 2ND ARE A SET WHEN YOU BUY THEM
Old May 13, 2004 | 07:13 PM
N2O's Avatar
N2O
Not that I think you do not know what you are doing, But when you put the gear sets back in did you install all the thrust washers. With out them the car will be hard to shift into gear because the 2 shafts are not lined up.
Old May 14, 2004 | 12:46 PM
RACESMART's Avatar
Default Re: need tranny help (N2O)
IT DID THS BEFORE I CHANGED THE GEARS/SYNCROS , AND YES ALL THE PART ARE PUT BACK TOGETHER IN THE RIGHT ORDER
Old May 14, 2004 | 03:21 PM
RACESMART's Avatar
Default Re: need tranny help - UPDATE (RACESMART)
WHAT IS THE MAIN INPUT BEARING IN THIS DIAGRAM?
http://www.hondaautomotivepart...82%29
Old May 14, 2004 | 08:24 PM
doublejz's Avatar
15
Old May 14, 2004 | 08:26 PM
doublejz's Avatar
Default Re: need tranny help - UPDATE (doublejz)
https://honda-tech.com/zerothread?id=596873
Old May 15, 2004 | 04:04 PM
RACESMART's Avatar
THANKS
Old May 15, 2004 | 04:29 PM
cajnatc's Avatar
I had a similar problem with my 96 civic when I put on an ATC extreme clutch kit. There is a bolt on the clutch pedel that goes through the flywheel. You have to lossen that nut and adjust it. I forget what which way to adjust it. Just play with it. What you doing is freeing up some room for the clutch to move releasing the pressure on the flywheel.
Old May 16, 2004 | 04:07 PM
RACESMART's Avatar
Default Re: need tranny help - UPDATE (cajnatc)
tried that didnt do anything
Old May 17, 2004 | 04:53 PM
cajnatc's Avatar
Damn yo, I'm not sure what it can be then.
Mugensr
Apr 12, 2007 09:56 AM
91_2.0_Si
May 20, 2004 07:05 PM
Pikachu
Apr 20, 2004 11:29 AM
REDBARON
12
Dec 3, 2002 04:09 PM
