Need some TPS help...please
Old May 2, 2007 | 04:28 AM
Turbo12acer's Avatar
Default Need some TPS help...please
2003 Acura CL 3.2 Type S 6 Speed
Alright here is my problem. I am getting a P0123 check engine light (high input circuit). Now the thing is I set it .45x volts and it ran fine untill I took it out and ran it. At about 5500rpm the motor shuddered and check engine light came on. I did notice that the idle was a bit higher at about 1100rpm. Parked the car at the store, came out and drove it normal for a bit and the check engine light went off.... Did a third gear pull and the light came on again. I'm almost 100% sure that its for the same code. Should I try to set it a bit lower to about .40V? Thanks in advance!
Eddie
Old May 2, 2007 | 01:12 PM
soulpwr's Avatar
Default Re: Need some TPS help...please (Turbo12acer)
The sensor needs to be replaced. Its a common problem. Check with the dealer, it may still be covered as its emmisions related. The newer models have extended warranties on certain items.
Old May 9, 2007 | 06:31 AM
would adjusting the throttle stop screw change anything?
Old May 10, 2007 | 11:25 AM
If I get a p0123 code (high circuit input) would that mean i need to adjust the tps at a higher voltage on idle or lower the voltage?
Old May 10, 2007 | 01:45 PM
ChickenH's Avatar
THROTTLE STOP screw adjustment changes the closed point of the plate making the voltage diffrent.
Old May 11, 2007 | 08:05 AM
now my question is...I adjusted the throttle stop screw right. Now I need to adjsut the TPS to teh right voltage?
jeff gonzalez
10
Jun 27, 2019 10:16 AM
scubacamper
Aug 30, 2015 01:06 PM
mcnos
Dec 18, 2011 11:53 AM
AMG
May 25, 2005 12:18 PM
yoshio006
Dec 17, 2002 06:18 PM
