need some technical help
Old Mar 25, 2003 | 05:14 AM
silcivic2k's Avatar
Default need some technical help
A few questions for 2000 civic dx stock engine with CAI, fuelrail, pressure regulator and exhaust mods:
I have noticed every time I tried to do something to increase the horsepower (such as adding CAI), I really felt a gain and my car was running very smooth, but after maybe 3 days my car is back to normal. Normal as if I didn't add anything to begin with. What am I missing here?
Second question is I need help on adjusting the fuel pressure for those mods I mentioned above. What do you think would be the ideal pressure? How will the performance be suffered if it's too low or too high?
Old Mar 25, 2003 | 06:45 AM
hs2000's Avatar
Default Re: need some technical help (silcivic2k)
Your just getting use to the added power. I would keep the pressure at stock, not enough mods to change IMO.
Old Mar 25, 2003 | 07:45 AM
you69's Avatar
Default Re: need some technical help (hs2000)
Yes i agree, and if NJ is anything like pa has been the past few weeks the outside air temp is all over the place, one day 70 the next 38. i have noticed that my own car will not run as strong in colder temps. this means noticeable changes nearly everyday.
Old Mar 25, 2003 | 08:56 AM
hs2000's Avatar
Default Re: need some technical help (you69)
Really? My car runs stronger in colder temps.
Old Mar 25, 2003 | 10:17 AM
Lsos's Avatar
Yeah, it works that way with everything you do to your car: suspension, engine...everything. You could be running 12s, and after a couple weeks your car would feel slow. If it comes down to that, you need to drive your friend's Taurus for a couple days and then get back in your car. It will feel fast again.
Old Mar 25, 2003 | 10:55 AM
silcivic2k's Avatar
Default Re: need some technical help (Lsos)
Hm...I understand what you guys mean by getting used to the gain and not feeling a difference but I don't think that's it. Somehow I feel a flow restriction of some sort and I did not feel it on the first 2 or 3 days. In fact, I'm starting to notice my gas mileage is getting worse. Does anyone know what is the stock fuel pressure for 2k civic dx?
BB6rude
Oct 8, 2007 04:04 PM
bumsta217
Oct 6, 2003 10:43 AM
LXguy
Jul 3, 2002 10:50 AM
