need some pics or diagrams
Old Jan 10, 2010 | 09:17 AM
taylormade's Avatar
Default need some pics or diagrams
of a set up for vacum maniflod ( golden eagle) and B&R catch tank the one with 6 out lets on a b16 turbo please
cheers
Old Jan 10, 2010 | 11:56 AM
95dxsir2's Avatar
Default Re: need some pics or diagrams
did you even search yet?
Old Jan 10, 2010 | 12:00 PM
taylormade's Avatar
i found pics in the turbo guide for the vacum mani and found pics of the catch can setup but idealy looking for diagram but can see any as they will be clearer
jdm inc's Avatar
x2!
Old Jan 10, 2010 | 12:08 PM
jdm inc's Avatar
https://honda-tech.com/forums/forced-induction-16/post-your-vacuum-manifold-setup-picz-2129009/
Old Jan 10, 2010 | 12:10 PM
taylormade's Avatar
thanks for the link i seen that one but i cant see which vacum hoses go where ect ect same with the breather kit
Old Jan 10, 2010 | 12:12 PM
95dxsir2's Avatar
catch can....6 lines......four on the valve cover, 2 on the back of the block.
vacuum manifold......depends on your set up.
there is TONS of info on this site.
Old Jan 10, 2010 | 12:13 PM
jdm inc's Avatar
the vac block goes to all your sources that need vac such as bov w.g. fpr boost gauge. u get the main vac source by T into your brake booster vac line
Old Jan 10, 2010 | 12:22 PM
taylormade's Avatar
thats cleared it up thanks guys
yeah loads of info on here been on here for a few weeks now only joined today tho.
im member of a few sites in the uk but im going to be building a b20 turbo engine at the end of the summer so came here as turbo hondas are more common in the us than they are is the UK,
thanks guys
Old Jan 10, 2010 | 02:47 PM
95dxsir2's Avatar
good luck!! and have fun
what wastegate are you using?
Old Jan 10, 2010 | 03:27 PM
taylormade's Avatar
tial wastegate un sure what turbo yet as not sure how much power i what to run, i also like the look of neukin manifolds iv heard some good stuff about them, apart from the time it takes to get one, you ever used one? are you running a turbo setup?
Bexe
Oct 13, 2009 07:33 AM
BLKTeg94
Apr 9, 2007 07:31 PM
Turbo_Mike
Sep 5, 2005 01:47 PM
smallttocs
Mar 3, 2003 10:25 AM
