need some help with the crank pulley assembly.
Old Mar 1, 2006 | 05:53 PM
EG_Civic_Si's Avatar
Default need some help with the crank pulley assembly.
Does the woodruff (21) key go on the inside or outside of the plate (16)?
I also noticed there is two different sides to the plate. Which way does it go on?
thnaks !
Old Mar 1, 2006 | 06:00 PM
adro2333's Avatar
Default Re: need some help with the crank pulley assembly. (EG_Civic_Si)
outside
Old Mar 1, 2006 | 06:14 PM
NJIN BUILDR's Avatar
The plates have a slight bevel and they flair out so the belt doesn't catch on the edge.The key goes outside of the plates.The key usually wants to slide out of the groove.After you slide the pulley on try to rotate it by hand to make sure it didn't slide out.Some times it takes a little patience to install it.
Glenn
tealchief
10
Mar 31, 2009 04:40 AM
Civic-Kids
Sep 13, 2007 07:49 PM
DC4 Rasta
Aug 27, 2007 12:50 PM
B!^A@
Nov 21, 2006 10:04 AM
h22aseemsgood
Mar 25, 2006 04:48 PM
