Need Inner Race for Front Hub
Old Mar 20, 2008 | 08:19 AM
Muckman's Avatar
Moderator in Chief
Default Need Inner Race for Front Hub
I recently powder coated my entire front suspension. Since I had to take everything apart, I replaced all the bushings, bearings, and ball joints. I pressed out the spindle from the knuckle. Removed the wheel bearing but the Inner race was a huge PITA. I searched around here and everyone said to slice it down the side to get it off. So I destroyed the race.
Now everything is powder coated, I go to order all the new parts and the race isnt sold seperately. Im not spending $260 on two new hub assemblies when all I need is the race!!!!!
Please help. Where can I get a new front inner race?
Old Mar 20, 2008 | 08:21 AM
Muckman's Avatar
Moderator in Chief
Default Re: Need Inner Race for Front Hub (Muckman)
This is what it looks like. This isnt mine. My race looks much worse as I had to destroy it to get it off.
*Edit: Respectfully removed Legion's pictures.
Modified by Muckman at 10:32 PM 3/21/2008
Old Mar 20, 2008 | 04:54 PM
non-VTEC's Avatar
the bearing race is part of the wheel bearing.......just buy a new wheel bearing?
Old Mar 20, 2008 | 06:09 PM
Muckman's Avatar
Moderator in Chief
Default Re: Need Inner Race for Front Hub (non-VTEC)
That part is NOT part of a new wheel bearing. I have two new OEM wheel bearings and it did not come with the race. There is no seperate part number for the race.
Old Mar 20, 2008 | 07:31 PM
NJIN BUILDR's Avatar
It is the inner race from the bearing.It stays with the hub when you press it apart.
Do a search on "wheel bearings" there are lots of pictures.
Old Mar 21, 2008 | 04:18 AM
Legion's Avatar
* B A N N E D *
Default Re: Need Inner Race for Front Hub (NJIN BUILDR)
How did you get that picture???? I only posted it in a kills thread, and that whole subforum is disabled. Nice to know someone stole it and re-hosted it. FYI, I'm starting a new forum and I'm going to move all my tech posts/write-ups from my various usernames off of honda-tech. Those images are my intellectual property and I will not hesitate to issue a cease and desist to honda-tech every time I catch them being posted here.
Aside from that - the inner race is most certainly part of the bearing itself. It holds the ball-bearings in. That's why (in the original thread) I talked about how I damaged the race on the brand new bearing and had to buy a whole new bearing again.
If you bought any "new" bearings that don't have that race, you most assuredly got hosed.
Old Mar 21, 2008 | 05:32 AM
non-VTEC's Avatar
Default Re: Need Inner Race for Front Hub (Legion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">How did you get that picture???? I only posted it in a kills thread, and that whole subforum is disabled. Nice to know someone stole it and re-hosted it. FYI, I'm starting a new forum and I'm going to move all my tech posts/write-ups from my various usernames off of honda-tech. Those images are my intellectual property and I will not hesitate to issue a cease and desist to honda-tech every time I catch them being posted here.
wtf.....are you kidding......a picture of a hub and bearing? hahaha.......whatever.....intellectual property? LMAOOOO
anyway.....muckman all new wheel bearings come with the races. you gotta look closer at the bearing. if you look down the center where the hub presses into you will see 2 pieces. the inner and outer race is attached to it. if there was no race you would see all the little ball bearings.......now if you purchased a wheel bearing and you can see all the ball bearings then you really did get ripped off..
Old Mar 21, 2008 | 06:23 PM
Muckman's Avatar
Moderator in Chief
Turns out I was sent the wrong bearing. So thanks guys for the help.
Legion, How about you stop being such a douche and just edit your original thread to remove the pictures if you care that much. And next time you post "intellectual property" on a public forum, have the foresight to tag it with your name.
Old Mar 21, 2008 | 06:27 PM
Legion's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Turns out I was sent the wrong bearing. So thanks Legion for posting pictures that helped me assess my situation and for giving me a correct solution to the problem.</TD></TR></TABLE>
Don't mention it
Old Mar 21, 2008 | 06:33 PM
Muckman's Avatar
Moderator in Chief
lol Thanks Legion. I removed your pictures.
stink
16
Jul 26, 2020 05:35 PM
Mr. Future
Jul 12, 2016 05:03 PM
mazdabish
Suspension & Brakes
Feb 26, 2016 12:25 AM
D21X
Oct 6, 2011 10:33 AM
Surewin
Mar 2, 2005 01:26 PM
