Need help whining noise
Old Feb 8, 2008 | 02:47 PM
hoseb007's Avatar
Default Need help whining noise
I get a whining/whistling noise. Whether the clutch is in or out, in gear accelerating, or stopped, it doesn't matter. I put a new ls haed on and new timeing belt.
i did use the search and found this it is almost the same but no sound
https://honda-tech.com/zerothread?id=2101288
the whining sound on youtube
http://www.youtube.com/watch?v=rm7tmGzU_yQ
Old Feb 8, 2008 | 03:32 PM
johnlear's Avatar
Banned
Default Re: Need help whining noise (hoseb007)
Sounds nasty! Might it be the idler pulley bearing? Did you fit a new idler pulley? If it's the old one then it might not have made a noise if then old belt was a little loose, but might now if the belt tension is a bit tighter (?).
Old Feb 8, 2008 | 08:16 PM
hoseb007's Avatar
Default Re: Need help whining noise (johnlear)
no i did not put a new one its still the old one
Old Feb 12, 2008 | 02:25 PM
hoseb007's Avatar
bump for i still need help can someone help
thanks
raybo
Jul 8, 2012 11:14 AM
EP3CHRiS
Sep 22, 2011 04:16 PM
immajackuup
Jul 18, 2009 11:00 AM
civic_driver
21
Jun 7, 2009 05:01 PM
GSRpoweredSI
Jun 20, 2007 01:13 PM
