need help vtec wiring
Old Mar 15, 2007 | 05:38 PM
gsrturboEK's Avatar
Default need help vtec wiring
hey wassup i just swapped out an ex 96 to a d15b with 3 stage vtec and im stuck on the red vtec wire need help on where it goes to on the ecu pins and one more thing i need the bracket for the power steering need help fast anyone?
Old Mar 15, 2007 | 10:36 PM
cvccvtec's Avatar
Default Re: need help vtec wiring (gsrturboEK)
92-95 ECU pins for vtec( Vtec solenoid A-4) ( Vtec pressure D-6) ( Knock sensor D-3
96-2000 ( Vtec solenoidA-8 ( Vtec pressure C-15 ( Knock sensor D-6 - 99-2000 SI C-3
Old Mar 15, 2007 | 10:48 PM
gsrturboEK's Avatar
Default Re: need help vtec wiring (cvccvtec)
hey thanks for the help but wich one is the red wire is it the vtec pressure
Old Mar 17, 2007 | 12:56 AM
gsrturboEK's Avatar
need help anyone??????
Old Mar 17, 2007 | 09:35 AM
HondaPartsHero's Avatar
Technical Hero
are you sure its 3 stage? does it have two VTEC solenoids? If not its not 3 stage. Anyway the motor probably doesn't have a pressure switch, so the only wire coming out of the solenoid is the VTEC solenoid wire which goes to A4
Old Mar 17, 2007 | 04:19 PM
gsrturboEK's Avatar
Default Re: need help vtec wiring (HondaPartsHero)
It is a 3-Stage vtec with two vtec solenoids. The green wire is already hooked up, I just need to know where the red wire goes to. The red wire from the solenoid.
Old Mar 17, 2007 | 04:20 PM
mR. Vash's Avatar
Bump, this n00b needs to know. Even though he did all my swaps on my car
Old Mar 23, 2007 | 10:11 AM
gsrturboEK's Avatar
Default Re: need help vtec wiring (mR. Vash)
all these damn honda tech guys cant even help me on this or what everyone says to come on here and problem solve but this site is only good for parts not tech help but thanks anywase
Old Mar 29, 2007 | 09:57 AM
craigie's Avatar
Check out this conversation about 3 stage Vtec about wiring.....
http://hondaswap.com/ecus-elec...58066/
The 3 Stage VTEC is ONLY JDM, there are relatively few people in the US that have
seen/installed/played with this VTEC.
I have the complete (P2J ECU also) 3 Stage Vtec D15B installed in my 91 CRX SI and am throwing engine codes......so I'm in the same boat as you......looking...
Old Mar 29, 2007 | 08:34 PM
gsrturboEK's Avatar
Default Re: need help vtec wiring (craigie)
hey man thanks alot thats one of the best help ive gotten so far man your freakin fantastic thanks alot well good luck with yours for i will need it also oh yeah and umm like i dont really know how to wire the red wire so i said forget about it and did with out it and ran the p2p ex ecu and man you feeel vtec stronger than any b series out of a single cam man that thing rocks
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
05 S2K Stoner
Oct 28, 2004 06:40 AM
SuperNemeSis
Mar 29, 2003 02:32 PM
HybridRexy
May 5, 2002 08:19 PM
