need help with vafc tuning
Old Mar 17, 2007 | 10:58 AM
broadway's Avatar
Default need help with vafc tuning
I have a D16Y7 fully bult with a to4e turbo and 450cc inj. I need a starting point on my vafc? I do have a wideband. My computer is a pm9.
Old Mar 17, 2007 | 06:53 PM
base-op.1320's Avatar
Default Re: need help with vafc tuning (broadway)
Just start of rich and slowly lean it out on the low map till you have an afr of 13-14.7 just driving around town - then go to your high map when the low is set and start off rich and tune it till you see around 11-11.5 afr at full throttle - Start in increments of rpm's from low to high tuning each thousand rpm to the given afr -for instance if you are at 2000rpm and floor it and see anything below 11 afr or if its popping rich then lean it out till you see 11 afr, then go to 3000rpm and so on - It would really help as to what setup you are running, like check valve on map sensor, an fmu, ignition retard of any kind, fuel, amount of boost. Not to sound negative but a long time ago I used a vafc for turbo and its not that good of a setup for turbo. and most of all good luck
Old Mar 17, 2007 | 07:58 PM
broadway's Avatar
Default Re: need help with vafc tuning (base-op.1320)
I have a missing link, no fmu, i did retard 3* and im doing 8 psi
Old Mar 17, 2007 | 09:04 PM
I have found that it helps to have like a 4:1 fmu along with a vafc to help assist the vafc in the on boost fuel levels but with that little boost you could go either way
wshondaman
Dec 24, 2004 01:45 PM
silverintegra83
Aug 6, 2004 11:38 AM
Boostless97Lude
Sep 6, 2002 02:11 PM
Evil EG
May 25, 2002 12:14 PM
