Need help with the V-AFC!!
Old Aug 21, 2004 | 07:11 AM
Fizzader's Avatar
Default Need help with the V-AFC!!
Wanted to know if someone knows an easy way to perform the Initial settings before starting the engine for the V-AFC for the Integra 97 GSR. The directions are confusing and need some help!!
thnx
Old Aug 21, 2004 | 07:48 AM
Antilag's Avatar
Default Re: Need help with the V-AFC!! (Fizzader)
I know your gonna hate this but you need to take it to a dyno to get a good tune without blowing it up. You could always set it around 0 untill vtec engages and maybe add 1 point of fuel on the rpms above vtec engagement. I really don't want to give you too much because I don't want to blow your motor up.
Old Aug 21, 2004 | 08:48 AM
zman's Avatar
Default Re: Need help with the V-AFC!! (9sech22civic)
He's asking about the initial settings. Like setting the number of sensors, # of cylinders, throttle sensor voltage....right?
Well its as easy as the steps describe.
Step 1- set to 6 of 6
step 2- set to 4
step 3- i don't think i did this step
step 4- make sure the arrow points UP
step 5-check the wiring diagram book for what type of vtec you have its in the table that tells you what diagram to look at i have a b16 so mines set to 1
step 6- push the gas all the way down for 10 seconds and then don't push the gas at all. For some reason this step confused me because i didn't know if the car was supposed to be running of not. I didn't have the car running for the initial set up just turned on the ignition switch (which doesn't mean your car should be running)
step 7- turn off the ignition
step 8- setting the VTC monitor i didn't do becuase i have a b16
START THE CAR and make sure everything works
Old Aug 21, 2004 | 10:27 AM
Fizzader's Avatar
Default Re: Need help with the V-AFC!! (zman)
I have 97 GSR .. I dont know about the step 5 looking for the number in the manual for the electrical diagram?? Also step 8 on your comment for the VTC what is this?? and do you have to set this up before start up..
thnx you for help!!
Old Aug 21, 2004 | 01:40 PM
zman's Avatar
i just checked the manual for confirmation and for step 5 (vtec type) set it to 1
step 8 only applies to cars that have IVTEC which yours doesn't, so you don't need to do step 8
glad i could help.
Old Aug 21, 2004 | 02:37 PM
Fizzader's Avatar
thnx .. but the step 5 i looked in the manual what function is that under? is it under the etc mode, or a different mode?
Old Aug 21, 2004 | 03:57 PM
zman's Avatar
yeah, go to the "etc" menu, then "car select"
then it will say cyl, thr, V/T
cyl - 4
thr - the arrow should point up
V/T - 1 this is where you set which type of vtec you have
94vtecmn
Apr 23, 2004 05:30 AM
ExVtec
Jan 15, 2004 02:51 PM
hondamama
Dec 2, 2003 08:20 AM
DjDrift
Oct 3, 2003 08:42 PM
IgniteTeg
May 2, 2002 07:23 AM
