Need help with strip head bolt thread
Old Nov 4, 2003 | 10:47 AM
lsvtecracer's Avatar
Default Need help with strip head bolt thread
I install arp head studs into my b18c1 motor and the thread inside the block gave out. I call arp and they said the bolt thread is 11 X 1.50. I call all the parts store and all the machine shop and nobody had the helicoil or insert to repair the bolt thread. I was wondering where do you guys buy the insert from to repair the bolt thread in the block once it's strip. Any help is greatly appreciate. Thank you.
Old Nov 4, 2003 | 10:52 AM
Spade's Avatar
Default Re: Need help with strip head bolt thread (lsvtecracer)
Weld in filler and drill and tap.
Old Nov 4, 2003 | 10:54 AM
Default Re: Need help with strip head bolt thread (Spade)
What kind of filler? thanks for the response.
Old Nov 5, 2003 | 08:26 AM
Marauder's Avatar
Think Spade meant to just weld up some aluminum in the head and retap it.
I would use a helicoil...but if you can't find one, then damn! Find a Snap-On truck that drives around and flag him down! They have em!
Old Nov 5, 2003 | 10:40 AM
Kataku2K3's Avatar
Default Re: Need help with strip head bolt thread (Marauder)
helicoil In the end you'll have a stronger thread surface than from the factory Good Luck
Old Nov 5, 2003 | 10:51 AM
Default Re: Need help with strip head bolt thread (Kataku2K3)
Thanks everyone...I was finally able to track down the correct helicoil for it. Thanks.
DeeEx Rex
10
Jul 29, 2010 11:02 AM
98ekgsr617
Sep 5, 2009 12:52 PM
runderwo
Aug 22, 2006 11:40 AM
Hondaholik
Jul 24, 2006 02:31 PM
sonofsam
Nov 7, 2005 08:26 AM
