Need help with speed sensor problem
Basically the speedo is not working and if it does work it is jumping all over the place without an accurate reading..
I know its my speed sensor but when I switched it out with a working one I still have the same problem..
If i wiggle the connector it will sometimes work and after maybe like 5 mins of driving it will stop working again. So I know it has to be a loose connection to the vss and the connector itself.
Anyone else ever have a problem where the connetor was loose and how I could possibly fix it.
-kevin
-kevin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one slow coupe »</TD></TR><TR><TD CLASS="quote">
I know its my speed sensor but when I switched it out with a working one I still have the same problem..</TD></TR></TABLE>
Then it's not the sensor. Logic > you
If you swap a part, and the problem remains, then it's not the part at fault, it's something else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If i wiggle the connector it will sometimes work and after maybe like 5 mins of driving it will stop working again. So I know it has to be a loose connection to the vss and the connector itself.</TD></TR></TABLE>
Check that connector and the wire carefully. Sounds like something got crushed/cut/sliced/mounged/beat up. In this case, the VSS sounds fine, check out the wiring harness.
Opps I meant I know its not the speed sensor. my typing error
The connector is loose tho, but nothing is broken.. like once the connecotr is on i can wiggle it around alot.. like sometimes if I wiggle it it will work.. sometimes not..
thanks for the imput
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one slow coupe »</TD></TR><TR><TD CLASS="quote">The connector is loose tho, but nothing is broken.. like once the connecotr is on i can wiggle it around alot.. like sometimes if I wiggle it it will work.. sometimes not..</TD></TR></TABLE>
Sounds like that connector needs replacement. It should fit tightly and without any slop. Anything else means that there's something amiss.
Was the harness abused ever? I'd check around and make sure there aren't any other connectors that are...compromised.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton »</TD></TR><TR><TD CLASS="quote">
Was the harness abused ever? I'd check around and make sure there aren't any other connectors that are...compromised.</TD></TR></TABLE>
no the harness is fine as it is the original from my car.
Im thinking maybe cause I have taken the tranny on and off so many times maybe it is just starting to get loose..
Whats the best way to fix the connector?
Cut one off another harness and jsut soder it on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one slow coupe »</TD></TR><TR><TD CLASS="quote">Whats the best way to fix the connector?
Cut one off another harness and jsut soder it on?</TD></TR></TABLE>
That's what I'd do. Trying to get the pins out and reset them is a pain, and you may end up breaking what's left of the connector. Make sure to heat-shrink the solder joints, and twist the wires tightly before you solder them (google for 'western union splice'). A good mechanical connection is 2/3 of a good solder joint.
imxyourxpassenger13
Jun 21, 2009 09:39 AM
iblingidawg
Dec 17, 2005 11:18 AM
