need help skunk 2 IM
Old Aug 14, 2002 | 03:43 PM
HYBRIDHATCH92's Avatar
Default need help skunk 2 IM
hope someone can help this is driving me crazy..........i'v got a 94 b18c i put on the skunk 2 IM i'm using the stock throttle body and throttle cable set up.......when i start the car in the morning it has an eratic idle....after the car warms up i here a pop then the car idles fine.........but if you hold the rpms around 1500 the idle will jump........does anybody know what this is......i cant see it being the TPS because i'v never touch it.....any help will be well appreciated
Thanks
Old Aug 14, 2002 | 04:14 PM
hybrid901's Avatar
Default Re: need help skunk 2 IM (HYBRIDHATCH92)
Use carb cleaners and check for a leak around the intake mani and tb.
Old Aug 14, 2002 | 05:05 PM
Kamin's Avatar
Default Re: need help skunk 2 IM (hybrid901)
did you replace the throttle body gasket?
Old Aug 14, 2002 | 08:15 PM
Default Re: need help skunk 2 IM (KAMiN)
yep changed the gaskets
dmossdrum91
Sep 20, 2015 02:16 PM
1989sircrx
10
Mar 27, 2010 04:26 PM
dafunkdawg
Jul 15, 2008 10:22 AM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
SpoolnG2
Oct 22, 2002 03:36 PM
