need help removing axle...
Old May 24, 2003 | 07:06 PM
xteg95's Avatar
Default need help removing axle...
okay i need to get my trans out and i need to get the axle out first. i followed my book and an article on c-speedracing. i got the fork out and the nut (castle nut) for the steering ball joint. i need to get the LCA off but the bolt where the castle nut used to be wont come off!??! I took it off my teg w/no problems, but this car has 120k miles and rust build up, i tried hitting the side of the LCA but nothing is budging....ANY HELP PLZ!?!?
btw this is for a 95 intgera ls.
Old May 24, 2003 | 07:40 PM
TREVER's Avatar
Default Re: need help removing axle... (xintegra01)
Beat a wedge or large chisel between the lca and knuckle.
Old May 24, 2003 | 07:44 PM
Cory man's Avatar
Default Re: need help removing axle... (TREVER)
A pitman arm puller will work without damaging the balljoint grease boot. If the boot is already screwed then use a balljt separator. One thing I do is put antiseize on the balljt shaft that fits into the LCA. I can literally lift up on the spindle and remove the balljt from the LCA. HTH
Old May 24, 2003 | 08:12 PM
h46it's Avatar
Default Re: need help removing axle... (Cory man)
I asked my friend that's a mechanic, he says that if there is a really stubron balljoint. He just uses a 48oz hammer. He said to give a good wack. It will come off. I tried it and it worked. I hope this helps.
Old May 24, 2003 | 08:16 PM
xteg95's Avatar
Default Re: need help removing axle... (h46it)
hit it where exactly, we tried hitting the end of the LCA, tried for like 20 mins w/nothing, also tried a clamp between the botton of the bolt and the top of the ball joint, similar to how the haynes manual describes...still nothing.
Old May 24, 2003 | 10:41 PM
WundedSaint's Avatar
prybar and 2 bigass hammers to knock it loose. One hammer on one side of the balljoint and then hit it on the opposite side
Old May 25, 2003 | 01:06 AM
3rdGteg's Avatar
Default Re: need help removing axle... (WundedSaint)
balljoint remover or just wack the sh#t out of it.
Old May 25, 2003 | 08:59 AM
Luke J's Avatar
Default Re: need help removing axle... (3rdGteg)
PB blaster and a big hammer
Old May 25, 2003 | 12:08 PM
yaya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">Beat a wedge or large chisel between the lca and knuckle.</TD></TR></TABLE>
um yeah, DONT do that. you dont wanna rip that boot
leave your shock attatched so it is pushing down on the lca and hit the ball joint itself, not the lca.....it should pop out, does for me
GSR_hatch936
Aug 6, 2007 02:26 PM
FRWYKNG
Nov 17, 2006 04:13 PM
Rod.
Jan 23, 2004 09:11 PM
Bspec18
Oct 28, 2003 08:03 AM
xteg95
May 25, 2003 04:44 PM
